2025 Aston Martin | Aramco F1 Team
-wkst-
-wkst-
Re: 2025 Aston Martin | Aramco F1 Team
The first half of the stint was quite ok for ALO, mediums and hards, was always in the train, but in the 2nd half of the stint tyre deg kills them - like last year. STR wasn’t that bad on the hards too, they extended and extended for the hope of a SC (rightly so - only chance for points), it didn’t come and in the last laps on the hards he was just sliding around and the race over.
RedNEO
40
TyreSlip wrote:
20 Apr 2025, 19:55
RedNEO wrote:
20 Apr 2025, 19:51
diffuser wrote:
20 Apr 2025, 19:07
Was gonna say we're gonna need an accident to get in the points.
We almost had one but luckily we didn’t. Bortoleto almost took Alonso out. Phew we could get lucky later if there’s a big pile up.
Most drivers would have crashed there, but Alonso's situational awareness is top notch.
He was inch perfect and the reward was only 11th. Deserves so much more. Floor update better deliver
RedNEO
40
diffuser wrote:
20 Apr 2025, 20:33
Considering the information we're hearing about AMR25 in the AM F1 WT and the rumors of having an Imola upgrade, that is still 1 month away .....That means the upgrade will be based on the AM F1 WT.
Praying for a transformative update
RedNEO wrote:
20 Apr 2025, 23:32
diffuser wrote:
20 Apr 2025, 20:33
Hallelujah!
Rikrikrik
Rikrikrik
diffuser wrote:
21 Apr 2025, 00:40
RedNEO wrote:
20 Apr 2025, 23:32
diffuser wrote:
20 Apr 2025, 20:33
Hallelujah!
That upgrade NEEDS make the car better, doesnt matter how much, but if these upgrades are another step back. I think 2026 will be another lab year.
vas_04614
vas_04614
If AMR and Merc WT numbers of AMR25 doesn't match they need to
  • find which WT is wrong
  • If it's AMR WT, then fix it and and re run AMR 25 current car and upgrades planned to make sure numbers match. Also restart 2026 car from scratch w.r.t WT testing
  • If it's Merc WT, then scrap upgrades already planned and find issues again using AMR WT and design new upgrade. For 2026 car, they should be fine with the work done till now I guess
  • Personally they should take time and may be plan only 1 upgrade for 25 car like for spain.
Alo_Fan
vas_04614 wrote:
21 Apr 2025, 08:00
I don't think it's that either tunnel is wrong, but the way our engineers were using the tunnels. We've already seen an article explaining that Newey was teaching them how to best use the tunnel etc. Alonso mentioned at the start of the season about how they found out a better way to use the tunnel too.
Otromundo
Seeing the amount of abrupt changes of direction ALO has to make to steer the car... it's a little scary. I think he's the driver who has to turn the steering wheel the most in corners.
I hope they find the magic key soon.
Believe half of what you see and none of what you hear.
vas_04614
vas_04614
Alo_Fan wrote:
21 Apr 2025, 10:08
vas_04614 wrote:
21 Apr 2025, 08:00
one doubt, if both tunnels are fine then shouldn't they get same numbers for AMR25 in AMR WT by following same processes/methods they used in Merc WT? if tunnels are different and it's not possible to use same processes/methods in both tunnels, then the only source of truth is actual car, so basically build an upgrade using new AMR WT and validate WT numbers with on track numbers
Alo_Fan
vas_04614 wrote:
21 Apr 2025, 10:27
Alo_Fan wrote:
21 Apr 2025, 10:08
vas_04614 wrote:
21 Apr 2025, 08:00
The AMR wind tunnel is definitely an upgrade, and should offer higher efficiency one would imagine. However, it's difficult to see the Merc wind tunnel isn't okay as Mercedes are doing fine with it, albeit they had some correlation issues with upgrades last season too.
SSJ4
SSJ4
DLR said nothing for miami, so another painful race. that chicane gonna be the stuff of nightmares
Xyz22
Xyz22
124
Alo_Fan wrote:
21 Apr 2025, 12:12
vas_04614 wrote:
21 Apr 2025, 10:27
Alo_Fan wrote:
21 Apr 2025, 10:08
Having an in house wind tunnel is not only about being better (i.e. providing more accurate results) but also about logistics.
Also, once again, Newey has been in charge of wind tunnel operations since he started working on racing cars. We are talking about an expert in this field.
TyreSlip
TyreSlip
SSJ4 wrote:
21 Apr 2025, 12:48
Alonso said after the race, "We have to get used to it. It's going to be very difficult to score points all season."
Nikosar
Nikosar
TyreSlip wrote:
21 Apr 2025, 14:25
SSJ4 wrote:
21 Apr 2025, 12:48
This is not the first time he has said this, perhaps a hint that nothing major will come out of the factory during this season? or trying to put some pressure on the team
zoroastar
Nikosar wrote:
21 Apr 2025, 14:34
TyreSlip wrote:
21 Apr 2025, 14:25
SSJ4 wrote:
21 Apr 2025, 12:48
i mean, its sorta just common sense. even if we bring good upgrades, everyone else will bring upgrades too, and the likelihood that theyll be scoring easy points is a bridge too far unless the top teams start crashing into each other. on normal weekends only 3 points are available anyway. lets hope for more australias haha
