2019 Mclaren F1 Team - Renault
charliesmithhd
67
Re: 2019 Mclaren F1 Team - Renault
charliesmithhd wrote:
11 Mar 2019, 19:27
Lucky wrote:
11 Mar 2019, 17:01
godlameroso wrote:
11 Mar 2019, 16:44
The rear wing will definitely be different, it looks like McLaren underestimated how much rear wing they need to balance the car.
"We only had our Melbourne rear wing with us. The produces for Barcelona too little downforce, "regretted McLaren boss Zak Brown.
I'm guessing Barcelona spec rear wing would not have the 'scoop' like the car currently has?
Was this part of the 'rear end stability' problem that autosport kept banging on about?
I don't know what they were banging on about, the team/drivers said it was a bit too much understeer - which is easy to see if you watch the videos through S3.
the EDGE
the EDGE
68
PhillipM wrote:
11 Mar 2019, 19:33
I very much doubt they do either, probably thought it sounded good so why not say it... a bit like everything they publish
RonDennis
RonDennis
11 Mar 2019, 19:29
11 Mar 2019, 19:27
Lucky wrote:
11 Mar 2019, 17:01
Sainz said on F1TV Pro that there were fixes coming, although he didn't say when.
Lucky wrote:
11 Mar 2019, 17:01
godlameroso wrote:
11 Mar 2019, 16:44
I can't find that quote anywhere.
I didn't see this listed anywhere. Apologize if it is a duplicate.
interesting reading https://f1metrics.wordpress.com/2019/03 ... -analysis/
charliesmithhd
67
diffuser wrote:
11 Mar 2019, 21:21
Nice find! Encouraging pace then, not too far from Redbull on average, although we don’t know fuel
mwillems
diffuser wrote:
11 Mar 2019, 21:21
That is interesting. I also wonder how much that would have improved had McLaren used a Barcelona spec rear wing, if that was the case. I would think that with more rear grip the tyres would move less against the track (Slide through corners or spin under accel) and wear at a slightly lower rate, or go faster and wear at the same rate, if the understeer was sorted anyway.
If the s3 testing issues are sorted by Aus then it feels like we might have a chance to push to the head of midfield.
<insidevoice>Dont get your hopes up. Dont get your hopes up... </insidevoice>
-Bandit
SmallSoldier
SmallSoldier
486
Luckily we are just a couple of days away from having the cars on track and even though FP1 and FP2 are just practice days, we will get a way better feeling on the car performance then... Really looking forward to it and for the team to surprise a few out there and hopefully lead the midfield... If that’s their starting point and without big correlations issues on the car that prevent development, it wouldn’t be surprising to watch the team close the gap to the top 3 through the season.
This year the team has every ingredient needed to start their path towards a Championship... They have a proven engine (probably not the most powerful, but at least the performance it’s competitive), they seem to have fix their correlation issues which allows rapid inseason development, they are getting both Key (in a couple weeks) and Seidl (in a few months)... And they have 2 drivers that even though aren’t at Fernando’s, Lewis or Seb’s level, are both hungry and have proven in the past to be fast (I expect a lot from Norris).
The best thing that the team has done this season is to keep expectations low... Hopefully they will exceed them all through the year!
Lucky
Lucky
157
RonDennis wrote:
11 Mar 2019, 21:04
AMuS
https://www.auto-motor-und-sport.de/for ... lona-2019/
_cerber1
275
Ground Effect
Ground Effect
Question, does anybody know how the race engineers were assigned? Who got Fernando's and who got Stoffel's?
FittingMechanics
FittingMechanics
16
Ground Effect wrote:
12 Mar 2019, 13:48
IIRC
Sainz got Tom Sallard (Vandoorne's engineer). I believe that the mechanics were the opposite.
Xero
32
11 Mar 2019, 21:24
diffuser wrote:
11 Mar 2019, 21:21
I think the point of the data was to use race sims where only pit stops were used between stints. From that you can make a reasonably easy assumption about fuel levels. It's certainly the most thorough summary we've seen so far, and bang on with my own personal feelings about the pecking order.
I think a big upgrade in the pipeline has to do with the bargeboards, not so much the actual bargeboards but the vortex generators on the foot plate. Other teams have them but McLaren does not.
In fact by comparison McLaren's bargeboards are rather barren, although a big improvement over last year, especially in regards to use of surface area.
McLaren had the VG on the foot plate last year, and comparing this and last year's design of this area shows just how much more surface area is available now.
GoranF1
GoranF1
151
Mclaren aero guy on Twitter says:
A rain of downforce coming...
