Red Bull RB7 Renault
PaulB
72
Re: Red Bull RB7 Renault
Pandamasque wrote:Have anyone noticed this wrinkled surface around the cockpit? Is it a badly applied sticker or...?
(Spa qualifying)
That could be a bad laminated carbon-fibre part or (I think not) maybe a bad coat of lacquer, we've also seen that on the Ferrari rear a few moths ago (look at the F150th Italia thread).
The Teams had do made their new carbon-fibre parts partially in a very short time for the race - but that head protecting component couldn't be new, because, your not allowed to amend the monocoque.
"Being second is to be the first of the ones who lose!" - Ayrton Senna
Paul Bischof
Milton Keynes, UK
MK2 2HL
http://paulsf1.wordpress.com/
this part is hollow to take up the mandatory and exchangeable confor foam elements for driver head protection.
Depending on ambient temp different Foam densities must be used.
Sure the part is very soft compared to a normal bodywork part and putting in and out the confor blocks takes its toll as well maybe..
Richard
Richard
PaulB wrote:Hello guys. At the moment, I'm working on my own paperboard RB7:
viewtopic.php?f=3&t=9909
Now, I have a few questons to the oil cooling system - especially the gearbox oil cooling.
The green line, I think, that's the oil line to the gearbox, but where is the line back to the radiator? Is that the red one? And what's that one, I've encircled in yellow? Something of the breather system?
Thanks
Paul
Are there two pipes where you've shown the green line? One supply, one return?
PaulB
72
richard_leeds wrote:Are there two pipes where you've shown the green line? One supply, one return?
I don't know. But now I know, that the gearbox oil-cooler is inside that part above, or better, behind the Airbox. I even don't know if that's the same line I marked which comes out of the radiator and that I marked along the engine to the gearbox. I also don't believe, that they put together the engine and the gearbox oil circuit. Jaguar F1 tried that in 200 and it didn't worked there.
Reason: edited quoted post by removing huge pic
Paul Bischof
Milton Keynes, UK
MK2 2HL
Richard
Richard
Of course, the oil radiator is piggy backed on the airbox in a lot of cars.
Then that makes the line you've picked part of the hydraulics - it looks more like a hydraulic line than coolant.
Predator
Hi.
Does anyone know the dimensions of the RB steering wheel?
Richard
Richard
PaulB might be able to help you. Have a look at his RB7 modelling thread viewtopic.php?f=3&t=9909&view=unread#unread
(pic by Sutton)
Reason: Added copyright notice
imightbewrong
imightbewrong
TheWiseOwl
TheWiseOwl
Rear wing has had a trim.
Not that much, certainly not compared to the other cars
TheWiseOwl wrote:Rear wing has had a trim.
Now that, is a Monza wing. Looks like about 32 degrees angle of attack.
dren
228
imightbewrong wrote:Image
That is awesome packaging.
Honda!
mx_tifoso
mx_tifoso
Impressive, they've really taken to developing the braking system cover. In the initial years it was a simple cover but now it's a lot more complex and sculpted.
240
You can reduce the size of the brake duct by taking in air in the annulus of the wheel rim.
I suspect this method also cools the inside of the rim as well, which may have some effect on tyre temperature.
