2026 Scuderia Ferrari HP F1 Team
Re: 2026 Scuderia Ferrari HP F1 Team
SoulPancake13 wrote:
11 Mar 2026, 21:53
Keep in mind that the claims Mercedes are holding back in the racers to prevent ADUO makes little sense. The FIA runs the engines on their dyno at full power. 2% performance deficit is ~10HP, which I think Ferrari would likely fall under
I don't buy those stories either. It doesn't work like that now. They are running at the power level which they think is "safe" for reliability. That's it. They might unlock more later in the season once they are confident in the reliability, but it's the same for the other manufacturers.
#ReleasetheADUO
wowgr8
wowgr8
29
I feel like hoping for Ferrari to challenge for the title would be like hoping for Red Bull to challenge for the title in 2020, the Mercedes advantage is far too big. Even assuming they can miraculously contain the points gap until ADUO kicks in (which sounds like an oxymoron), what are the chances the brand new PU is fast and reliable enough?
f1316
88
wowgr8 wrote:
11 Mar 2026, 21:59
Thinking about it, I wonder if there’s a bit of tactics here to game the ADUO system a bit? Ie might it be strategically wise to start a little bit behind and ensure you get that in-season upgrade after race 6, give yourself time to work on the concept, and potentially even have an advantage for 3/4 of the season?
Don’t get me wrong, I don’t think anyone would hold of building the the best engine they can - and would prefer to start the season on top - but given the challenges, they may be banking on ADUO as part of the strategy.
urtsee
urtsee
11 Mar 2026, 21:53
If the Mercedes customer teams can't work out how to run the unit to its full potential, perhaps the FIA might also struggle to do so.
f1316
88
Don’t know if this was already posted but supposedly they’ll test new software for harvesting in China (apparently mimicking a trick they observed RB and Mercedes using): https://scuderiafans.com/ferraris-digit ... -in-china/
catent
f1316 wrote:
11 Mar 2026, 22:33
First time I am reading this. Thanks for sharing.
johnnycesup
johnnycesup
f1316 wrote:
11 Mar 2026, 22:33
Is this website trustworthy?
Xyz22
Xyz22
125
johnnycesup wrote:
11 Mar 2026, 23:13
f1316 wrote:
11 Mar 2026, 22:33
No, it's not.
f1316
88
Xyz22 wrote:
11 Mar 2026, 23:38
johnnycesup wrote:
11 Mar 2026, 23:13
f1316 wrote:
11 Mar 2026, 22:33
No, it's not.
I wouldn’t be that definitive. I’ve read things on there that are speculative but also others that turn out to be true. Usually, they quote other sources (eg Italian press) although I will admit this one is a bit vague (“our sources”).
Take everything you read there with a pinch of salt, for sure, but I wouldn’t entirely dismiss it out of hand.
dans79
267
The article isn't suggesting anything magical.
Every team on the grid is going to be working at 100% to find ways of extracting every watt of power out of the ice they can. As the article suggest the hard part is doing it in a way that isn't a detriment to the drivers.
202 105 104 9 9 7
sucof
37
Yeah, sadly every 6 year old who just learned how to write can write such an article.
The part where they talk about "the expected 5 second improvement over the season" is a clear and funny giveaway :D
Anyways, of course every team is constantly working on their new software. They would be fools not to.
I still do not know if there is any hardware limitation to change your harvest or deployment to be what like Mercedes has. I think this is the main question in the current situation.
sucof wrote:
12 Mar 2026, 11:26
One of the difficulties of driving with the lower gears is the gear ratios. Ferrari and Mclaren have a very short first gear. It probably helps them to keep the revs up at the starts, but then it's harder to shift down into first during a lap without locking the rears. So that would be a hardware limitation. They are allowed 1 in-season update to the ratios.
#ReleasetheADUO
edit: wrong thread
#ReleasetheADUO
Farnborough
Farnborough
152
"One of the difficulties of driving with the lower gears is the gear ratios. Ferrari and Mclaren have a very short first gear. It probably helps them to keep the revs up at the starts, but then it's harder to shift down into first during a lap without locking the rears. So that would be a hardware limitation. They are allowed 1 in-season update to the ratios."
Not necessarily.
This can be blended with throttle modulation during that downshift period I believe. There appears at least some scope within control regulation to achieve this.
Failing that, a strategy of taking 2nd gear earlier than conventional approach will likely bring gains too.
Farnborough wrote:
12 Mar 2026, 12:23
Not necessarily.
What I mean is that engine RPM is tied to the wheel speed. So if 1st gear is shorter, you have to wait longer before you can use it. The engine is not a "free-revving" device. It has a rev limit. Therefore teams with shorter gears cannot enter 1st until the synchronized RPM is below the engine's rev limit. iirc, the gearbox would just reject the downshift if it's too early.
Also, I would assume that Ferrari is already maximizing the 2nd gear entry point.
#ReleasetheADUO
