Apologies but I think Your friend's figures are inconsistent.Petroltorque wrote:I have attached the reply I received from the involved individual. It's from another well known site. Up till then I believed max output was ICE plus ERS but that would not have explained Mercedes advantage.
Hi, Petroltorque
You are not right. 50% is TOTAL, not just ICE.
F1 Mercedes today has (roghly) 830-840 HP.
Ferrari is 30-40 HP less.
Renault 50-70 less.
Honda, I don't know.
Story of just ICE having 50% efficiency is science fiction. And that is deliberately placed to mad up opposition and make a smoke.
That ICE efficiency NOT exist.
And difference on ICE alone is in region of
M-B ~ 610-615
F~ 600-605
R~590
ERS-Kinetic is fixed at 120 KW
Real difference comes from ERS-Heat. There goes also HOW you use this energy, and how you storage it.
Mercedes did something and they are efficient in that.
Shortly, problem is in s/w deployment and Merc did good job on it.
ERS-Heat can make max. 60 HP. After that they brake ICE and diminish power output.
I think above is enough to make it more obvious for all of us
This is evidence of double counting. The MGU-H cannot add power to the wheels, only the MGU-K can, if Mercedes were doing this, they would have been DSQ long ago. The only way what you say makes any sense is that if in full power mode, the ICE can produce the claimed 60 hp more because of the reduced back pressure from the turbine being driven by the MGU-H.Petroltorque wrote:Full power mode is SS 745+ES 80 or 830bhp. that complies with an overall efficiency of around 50%.
A power output of 910bhp is and efficiency of around 55%. The issue I have is that if the motive power is derived from fuel only where has that extra 5% power come from?
The figures you have quoted are Henry's not mine. As I understand it Merc are compounding the power at the crank by using Energy from the ERS-H. He did not say that energy is being delivered via the MGU-K.Cold Fussion wrote:This is evidence of double counting. The MGU-H cannot add power to the wheels, only the MGU-K can, if Mercedes were doing this, they would have been DSQ long ago. The only way what you say makes any sense is that if in full power mode, the ICE can produce the claimed 60 hp more because of the reduced back pressure from the turbine being driven by the MGU-H.Petroltorque wrote:Full power mode is SS 745+ES 80 or 830bhp. that complies with an overall efficiency of around 50%.
Who even is this person with the random email? You obviously don't know him so why should we trust him? The contents of his email don't lead one to believe he has any insider knowledge. Furthermore, your interpretation of he contents of that one email appear to be incorrect.
In your example you are assuming a power from the ICE of 610 HP. That is an efficiency of around 37 %. You then add the 60 of the MGU-H (3.6%) to give 670 ( 40.4%). The only way this power can get to the road is via the crankshaft. The ICE drives it directly but the MGU-H has to send its contribution via the MGU-K. So Self Sustain, I.e. The only energy input is fuel, is 670 HP. You cannot add anything from the ES.Petroltorque wrote:From the figures given the MB output is 610 for the ICE alone which is then compounded by the ERS-H by a further 60bhp. That 60bhp represents the maximum amount of energy you can take off the turbo/compressor before adversely affecting ICE performance. That 60bhp is free in that it's not counted in the total output of the MGU-K. So total output is Self sustain ( ICE+ERS- 610+60) 670 + MGU-K 160 = 830bhp
Henry your analysis raises some very interesting points. As I understand it that 45% efficiency can't be achieved by the ICE alone but has been achieved by incorporating the power of the turbo/compressor/MGU-Heat (ERS-H) that would be 745bhp.
ie SS-745bhp
Very well said!!! I was going to make a lengthy post but you did it with less words and much better then I.lolringo wrote:I see a lot of errors here.
To be clear:
THE MGUH/MGUK POWER SHOULD NOT BE ADDED TO THE ES/MGUK POWER to determine the efficiency of the power unit.
It just doesn't follow first law concept of thermal efficiency.
this is wrong: total power to be considered for thermal efficiency = ICE + (MGUH->MGUK) + (ES->MGUK)
this is correct: total power to be considered for thermal efficiency = ICE + (MGUH->MGUK)
the ES is only boasts improved fuel economy in terms of litre/km that's about it.
The true thermal efficiency is the self sustaining efficiency alone. Anything else is hogwash and smoke and mirrors. The thermal efficiency only accounts for power that is developed by the fuel instantly and continuously; therefore the energy store should never be included in the calculation.
Brake Thermal Efficiency must only be the ICE and the MGUH while it directly feeds the MGUK.
If a team has a lousy MGUH that means their thermal efficiency will suffer. so for example if you ICE has 650hp and MGUH can only muster 60hp to the MGUK for self sustaining mode, then total output is 710hp. End of story; there's no other way to look at the thermal efficiency.
if your ES is supplementing the the 60hp from the MGUH, then yes output can be 650 + 160hp = 810hp. but this cannot be used to determine thermal efficiency.
What proves this best is if you charge the battery fully from a wall socket then put it in the F1 car. If you deploy it on an outlap and it supplementsthe ICE power, it's dubious to claim that wall charged battery as power produced by the fuel.
ES charged from the brakes also cannot be used for thermal efficiency calculations. In a nut shell the ES is out of the equation.
Absolutely correct.Petroltorque wrote:Ah Henry I see where you are coming from but th CRUX is that energy from the ERS-H is NOT limited by the 120Kw MGU-KINETIC it is in addition. So Merc are pushing an Extra 45Kw Lap on Lap on top of the MGU-KINETIC.
Surely that is incorrect as the MGU-k can only ever put out the 160hp so if it is already applying 60 of those, as directy offereed by the MGU-h, then there's only 100hp more to be produced. As in: 750hp.ringo wrote:I see a lot of errors here.
To be clear:
What a silly question. The efficiency lies in capturing some of the energy that would otherwise have gone to waste through the exhaust. It needn't go to the ES because it can be sent to the crank shaft via the MGU-k instead, thereby adding to the amount of mechanical work rendered per amount of fuel consumed, increasing the efficiency.henry wrote:The MGU-H has two outputs. It can drive the MGU-K or it can charge the ES.
If the ICE is making 610 HP and the MGU-H is sending 60 HP to the ES, what is the efficiency?
