At the same time, when cars have had DRS stuck open, they don't get disqualified for it. (usually they retire the car anyway) but I dont recall anyone being DSQ for a stuck open DRS as an example of damaged parts being classified as illegal.Vaexa wrote: ↑13 Nov 2021, 00:12This one is very difficult to say. Vettel's DSQ in Hungary was, if my memory serves, due to a failure in a fuel cell valve. That could be argued as being damage. I can't immediately figure out the consequence of being technically noncompliant as a result of damage from the sporting regulations or the FIA sporting code.
To my knowledge, TDs are not published anywhere or amended to the current year's technical regulations. This one is pretty much just black magic to me. I wish there was more I could glean from the regulations right now, but we'll just have to wait.zibby43 wrote: ↑13 Nov 2021, 00:17Thanks. In the language of Bauer’s report, he refers to a TD.Vaexa wrote: ↑13 Nov 2021, 00:12This one is very difficult to say. Vettel's DSQ in Hungary was, if my memory serves, due to a failure in a fuel cell valve. That could be argued as being damage. I can't immediately figure out the consequence of being technically noncompliant as a result of damage from the sporting regulations or the FIA sporting code.
Excessive bending?
You do realise the drs probably opened like 85.5mm rather than 85 or something trivial. He gained all his time in sector 2 in the corners, turn 8 and 9 in particular. Not on the straights.pantherxxx wrote: ↑13 Nov 2021, 00:18If FIA don't disqualify him for this, then this game is rigged. Of course that's why he was so fast.
Perhaps mercedes should alert the fia to verstappens upper rear wing element flapping up and down end of straight, looked like it was opening miles further than usual
I believe the slot ends up being the same size as long as the actuator isn't bending. I believe (this is conjecture, though) that the main plane of the rear wing may be bending too much on Hamilton's car.Mchamilton wrote: ↑13 Nov 2021, 00:24Perhaps mercedes should alert the fia to verstappens upper rear wing element flapping up and down end of straight, looked like it was opeeneing miles further than usual![]()
Yeah, because he was running a much steeper wing than RBR. That also increases the DRS gain more. All under the smoke and mirrors cover of an fresh engine.Mchamilton wrote: ↑13 Nov 2021, 00:22You do realise the drs probably opened like 85.5mm rather than 85 or something trivial. He gained all his time in sector 2 in the corners, turn 8 and 9 in particular. Not on the straights.pantherxxx wrote: ↑13 Nov 2021, 00:18If FIA don't disqualify him for this, then this game is rigged. Of course that's why he was so fast.
I do remember one case where they retired the car otherwise they would have been DSQed. See if I can find it…NathanOlder wrote: ↑13 Nov 2021, 00:18At the same time, when cars have had DRS stuck open, they don't get disqualified for it. (usually they retire the car anyway) but I dont recall anyone being DSQ for a stuck open DRS as an example of damaged parts being classified as illegal.Vaexa wrote: ↑13 Nov 2021, 00:12This one is very difficult to say. Vettel's DSQ in Hungary was, if my memory serves, due to a failure in a fuel cell valve. That could be argued as being damage. I can't immediately figure out the consequence of being technically noncompliant as a result of damage from the sporting regulations or the FIA sporting code.
