Petition to FIA - 2026 rules canceled, V10s in 2028
JordanMugen
86
Re: Petition to FIA - 2026 rules canceled, V10s in 2028
McLarenHonda wrote:
19 Jul 2025, 19:07
Any idea of how many RPM these V6 Hybrids would be able to hit if there was no limit? 15K?
They would rev less not more with no limit. They only rev above 11,500rpm because maximum fuel flow is not permitted below this rpm (IIRC).
To have high-revving turbo engines, you need pseudo-NA engines with a very low boost limit like in CART.
650
JordanMugen wrote:
20 Jul 2025, 17:33
... They only rev above 11,500rpm because maximum fuel flow is not permitted below this rpm (IIRC).
10500 rpm (IIRC)
WardenOfTheNorth
Tommy Cookers wrote:
20 Jul 2025, 10:15
WardenOfTheNorth wrote:
19 Jul 2025, 22:07
EV's are far more energy efficient... than ICE....
nonsense
as most electrical energy is made by ICE (or other thermal) action
I see we're ignoring science and facts in favour of selective editing.
I was talking purely about as a means of propulsion, not the whole energy cycle. Though even with the latter, EV's are more efficient.
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
vorticism
vorticism
337
mzso wrote:
20 Jul 2025, 13:27
vorticism wrote:
19 Jul 2025, 19:55
They're no good when it comes to converting chemical energy into kinetic energy. Which may be shocking news for some. Where this now places electric motors on arbitrary superiority-inferiority spectra I'm not sure. I'm off to reddit to find out.
A motor purpose is to move not to convert chemical energy. And electric motors a better when it comes to performance aspect. Efficiency, torque, power to weight, responsivenes.
Of course, but you said, "electric motors are just plain superior in all regards," hence my prodding. Makes little sense to rank apples to oranges. Hence my joke, paraphrased: "Well, they suck at converting chemical energy to kinetic energy." It seems the joke was lost on some, and I was presumed to be a heretic of the Electric Vehicles religion (I am not). If you had only a can of fuel and no electricity you'd be wanting an ICE.
19 Jul 2025, 22:07
vorticism wrote:
19 Jul 2025, 19:55
Sure. In a world where 70-80% is lower than 25-30%
EV's are far more energy efficient, whatever way the energy is stored (don't forget that batteries use chemical energy), than ICE....
Percentages in a vacuum, hmm. Compelling, they do look sciencey, but an EV is not an electric motor, and, electric motors convert electrical energy to kinetic energy. Work from there. You must be in your early years at EV seminary. I look forward to you becoming a deacon or vicar some day.
SB15 wrote:
19 Jul 2025, 22:10
vorticism wrote:
19 Jul 2025, 19:55
...I don't know why the FIA keep sticking gigantic full width front wings onto their cars the past twenty years. Still this exists in '26, giant endplates on the FW larger than FW elements themselves. I am though optimistic about the new bargeboard and semi-flat floor concept.
Turns out the Floors maybe completely flat, from recent reports. So, the emphasis on the ground effect will be basically non-existent next year and it's all about CoG next year.
We could see not only massive changes in aero and engine packages, But also a massive overhaul across the grid in the mechanical aspect as well, because now for certain teams, they are not dependent on the pull-rod in the front anymore. And the downwash sidepod concept will more than likely be scrapped by many teams. So will there be rake concepts coming back? We'll have to see.
Plus, looks like wheel covers may no longer exist next year, because the wheel rims will be exposed, so the whole brake cooling advantage is out of the window.
Really, the FIA are going back to the 2017-2021 regs just more simplified with active aero. I never seen a bigger regulation change than this... The ground effect era really failed.
Good points. First part: Depends on what you mean by floor and flat. There is freedom to undulate the surface of the floor, but also there's not much room to do it within, due to the legality box. I say semi-flat also because the front of the floor is permitted to ramp upward, which was not permitted on previous flat floor F1 cars.
Comparing to 2017: I'm expecting to see rake return, although the changes relative to the 2009-2021 floors with the the front ramp and the taller, longer rear diffuser, might change the importance of rake. If they get suitable DF from these features, maybe they won't chase high rake angles. Which affects CoG and choices to use pullrod or pushrod at the rear axle. The lack of a large beam wing + the low rear wing implies we might see the same sort of low engine cover outlets from 2017 onward, that exited between the suspension arms , but I think some teams might take advantage of the larger louver boxes and we'll see new concepts there.
The wheel covers are going away, replaced by the discs (see Qvist's renderings on X) but the cake tins ("drum") will still be present, along with the same sort of inlet and outlet ducts. If there was any interplay between the cake tin and the wheel and wheel cover in the current formula, then this is being altered.
As to whether the 2022 regs failed: Mclaren and Red Bull might disagree. Regardless, the past couple seasons have seen a very tight grid--was this not the goal? It's interesting that even within a tight field Mclaren are making it look like it isn't. How to sum it up... RB mastered the tenths, Mclaren have mastered the hundredths (?). That the 2022 regs lasted only four seasons seems odd. When was the last time a regs cycle was so short?
Alt history moment: had Mateschitz lived longer, what would we have seen from RB in '24 and '25? The RB20 and RB21 that never were, against McLaren. Where would Newey have taken further development? Would the RB21 have ended up looking like the MCL39, or something different.
14 Jul 2025, 12:02
race engines have had one bank exhausting via a turbocharger and the other bank exhausting directly to atmosphere
Do tell!
mzso
mzso
67
20 Jul 2025, 16:54
mzso wrote:
20 Jul 2025, 13:37
.. mining crude oil, refining it, hauling around with ships trucks, pipes, etc...
these combined have only the same % efficiency loss as the combined electric equivalents
Not at all. Electricity generation is far more versatile as well as, so differences can vary.
ENGINE TUNER
ENGINE TUNER
25
PlatinumZealot wrote:
20 Jul 2025, 13:48
ENGINE TUNER wrote:
18 Jul 2025, 20:04
17 Jul 2025, 12:41
Have to say, I'm currently listening to a load of LMP cars going past (not sure which - I think it's an open test day for various customers) and the variety of exhaust notes is fantastic.
The more I think about it, the more I'd be in favour of them opening up the PU regs to allow different PU layouts.
Not sure how they'd regulate to keep them in the same of ballpark performance-wise, but that's for people smarter than me.
They were all converging to 1.5L v6 in the 80s, then they all converged to v10 in the 90s. They would probably all converge to a 1.6L v6 or I4 if full choice was allowed now. There is no BoP in F1 so they will all eventually converge to the best solution which with today's technology is pretty what we have now a 1.6Lv6 turbo hybrid with mguh, the only possibly better option is the 1.6L I4 turbo hybrid which was supposed come in 2013, but Ferrari forced a switch to v6.
The manufacturers came together and agreed that 1.6Lv6 is what they wanted and what was best for them. This was not something the FIA forced on them.
If my memory is correct, they started with intention to go do V8 when most teams were running with one cylinder models.... There was also talks of straight fours like BMW in the 1980's.. The V8 was too expensive and made too much friction and the l4 would need a bracing frame around it, and so the V6 was the best compromise. Something like that.
For the next generation I'm hoping they go with V10 naturally aspirated Hybrid and nothing less.
It was agreed in 2010 that an I4 would come in for 2013, Ferrari threatened to use their veto until a v6 was agreed upon because Ferrari said they would never run an I4 in a road car. The brace(subframe) complaint was an excuse, smoke and mirrors, the current v6 has bracing built into the valve covers. An I4 would have been cheaper and even more efficient, and nearly every manufacturer in the world makes a 1.6 or 3L turbocharged I4, except for Ferrari.
Anything naturally aspirated is outdated, obsolete, inefficient and foolish. Carrying 100kg more fuel just to hear some more vroom vroom that will force most to wear hearing protection is foolish. Reintroducing refueling that will take away from on track action and allow for more Alonso race fixing is foolish.
WardenOfTheNorth
vorticism wrote:
20 Jul 2025, 21:08
mzso wrote:
20 Jul 2025, 13:27
vorticism wrote:
19 Jul 2025, 19:55
19 Jul 2025, 22:07
vorticism wrote:
19 Jul 2025, 19:55
SB15 wrote:
19 Jul 2025, 22:10
vorticism wrote:
19 Jul 2025, 19:55
14 Jul 2025, 12:02
Do tell!
Percentages were not in a vacuum, they were based on EV cars compared to equivalent ICE cars.
