Mercedes W17
SiLo
144
Re: Mercedes W17
04 Feb 2026, 22:35
https://i.ibb.co/5h75M4TZ/20260204-203149.jpg
The floor corner detail on the mercedes
It’s really hard for me to get my bearings on this. What an I looking at and from what angle?
Felipe Baby!
Re: Mercedes W17
SiLo wrote:
04 Feb 2026, 22:56
04 Feb 2026, 22:35
Rear floor corner ahead of rear tyre
Stu
Re: Mercedes W17
04 Feb 2026, 23:01
SiLo wrote:
04 Feb 2026, 22:56
04 Feb 2026, 22:35
https://i.ibb.co/Hp14Vr8T/HAKeo2g-WUAEh-H05.jpg
https://i.ibb.co/ksXgzMCg/20260204-203149.jpg
Not sure whether I’m seeing things, but that looks like an additional element above the floor surface!!?
Re: Mercedes W17
Stu wrote:
04 Feb 2026, 23:55
04 Feb 2026, 23:01
SiLo wrote:
04 Feb 2026, 22:56
Yes. Such things have been legal for ages. Stay within 50 mm of the floor and you can pretty much put anything.
Re: Mercedes W17
Beware of T-Rex
Stu
Re: Mercedes W17
I noticed that too.
To be honest when I saw the VCARB actuator solution my first thought was why haven’t they mounted it underneath like a good-old-fashioned strake! Maybe that is what we are seeing here? Their post season Abu Dhabi test mule had a very groovy ‘Heath Robinson’ set-up, that looked to be outboard mounted (but that could have been due to the existing adjustment mechanism?).
Lasssept
118
Re: Mercedes W17
brakeboosted
Re: Mercedes W17
Stu wrote:
05 Feb 2026, 10:07
I noticed that too.
The actuators can only be in one of three places.
Those are just strakes mate. The actuator is in the nose. If you were in any doubt, the hole in the top of the nose is where the actuator is accessed to adjust static flap angles.
Re: Mercedes W17
Hi everyone,
with the first 2026 cars appearing on track, I’ve been looking closely at how different teams are implementing front-wing active aerodynamics in Low Drag mode. One detail that stood out is that Mercedes (and Aston Martin) appear to actuate only the rearmost front-wing flap, while most teams — Ferrari included — are moving two elements.
We’ve put together a technical analysis explaining why this may be the case, focusing on wing structure, pylon attachment and load distribution, rather than just regulation interpretation.
The key point is that Mercedes’ front-wing pylons seem to structurally integrate the main element and first flap, leaving only the trailing element free to move. If that last flap carries a large share of the total load, flattening it could still deliver a strong drag reduction, potentially similar in effect to DRS, but with different balance implications.
Full analysis here (in English):
https://www.newsf1.it/f1-2026-why-merce ... on-martin/
I’d be very interested to hear your thoughts on whether this single-flap Low Drag approach could offer better efficiency, or if it risks limiting balance control compared to Ferrari’s two-flap solution.
SB15
SB15
Re: Mercedes W17
Although kinda blurry, here are pictures of the rear suspension
matteosc
matteosc
32
Re: Mercedes W17
Sorry if I missed this topic begin discussed already or if this belongs to a different thread.
Rumors are that Mercede's engine has an additional "micro" combustion chamber, comunicating with the main one when the engine is cold. This is used to measure the compression ratio as 16:1. When the engine is warm, this "micro" combustion chamber is closed by thermal expansion and the effective compression ratio is increased.
Do you think this is actually doable? Considering that the latest news is that the compression ratio will now be measured with a warmed engine, does that mean that Mercedes will have to modify its engine?
Farnborough
Farnborough
152
Re: Mercedes W17
matteosc wrote:
07 Feb 2026, 00:15
There's a whole dedicated thread on this topic viewtopic.php?t=32394&start=465 that effectively keeps it away from these car focused one's.
Lasssept
118
Re: Mercedes W17
Kemal Sengul
Joe Portlock
Lasssept
118
Re: Mercedes W17
Re: Mercedes W17
Beware of T-Rex
