2019 Mclaren F1 Team - Renault
Ground Effect
Re: 2019 Mclaren F1 Team - Renault
Thanks guys, both replies are very insightful.
FittingMechanics
FittingMechanics
I wouldn't really jump to conclusions. Track is gripping in, Sainz was quite fast when he did his run (I believe he was just behind the top 3 teams), but late "comers" jumped over him.
Also, if you check sector times, Sainz's S3 is 2 tenths slower than Norris did on his lap that was 6-7 tenths slower. This surely means that they haven't really been pushing the car or going for maximum speed. If one was to use logic, they probably do some correlation work and test whether the new bits they brought give intended results, all of which is unsuited for 1 lap comparisons.
FittingMechanics
FittingMechanics
Soymotor reports Sainz had a small issue with power steering but that mechanics sorted it out. Probably cost him some track time (he was in the pits for a while when Norris started doing a longer run). All in all, decent session.
SmallSoldier
SmallSoldier
488
FittingMechanics wrote:Soymotor reports Sainz had a small issue with power steering but that mechanics sorted it out. Probably cost him some track time (he was in the pits for a while when Norris started doing a longer run). All in all, decent session.
He complained on the radio that he couldn’t steer properly and that he thought the power steering was gone... A quick check in the pits and he was out again.
max_speed
max_speed
looks like marko was right , they might be at the back. i do not know what mclaren is doing but so far nothing exciting in FP2
_cerber1
301
Because МхМ
101FlyingDutchman
101FlyingDutchman
Wow. Struggle to get through the first bit of Quali. Fighting with Racing Point 7th/8th/9th fastest team
max_speed
max_speed
i am sure they will be not get out of Q1.
101FlyingDutchman
101FlyingDutchman
Out of or out in? I’m not hopeful at the moment. Nothing I’m seeing is screaming loads of performance left in tank
FittingMechanics
FittingMechanics
101FlyingDutchman wrote:
15 Mar 2019, 08:06
FFS guys. They are running on medium tires, doing a longer run. Probably a race sim.
I'm expecting they do a "qualy" sim now.
GoranF1
GoranF1
149
The reality is hard.
max_speed
max_speed
15 Mar 2019, 08:18
they did a soft tyre run,already as reported by autosport.
101FlyingDutchman
101FlyingDutchman
Exactly. I’m looking at the data and that’s my observation. No need to use FFS.
Reality is we are at the back of the mid field on evidence
FittingMechanics
FittingMechanics
Is there a stint data?
What should tell you to not jump with conclusions is the fact that Ferrari on soft tires is P5 and P9. Does it mean Ferrari is 4-5th team on the grid? No. Team will probably know today how they stand (through analysis), but we will not know it until qualifying and race.
max_speed
max_speed
15 Mar 2019, 08:26
i admire your optimism but lets meet tomorrow and here you again after quali. bottom line is mclaren is at the back.
