Lotus E20 VD
Owen.C93
Owen.C93
191
Re: Lotus E20 Renault
Seems unnecessary.
MarkedOne8
MarkedOne8
James Allen:We will continue to dial in the new device that we ran in Hockenheim with Kimi. Despite the difficult weather conditions, we did get a good feel of its performance potential from the free practice session and we aim to take it on a step at the Hungaroring.
That means they are aiming to use the special DRS system for race in Hungary?
Fernando Alonso is the best pay-to-drive driver in F1 with the biggest amount of money behind him.
http://f1bias.com/2012/04/05/truth-abou ... nder-2008/
Neno
Neno
-29
maybe, if performances of the car with him are much better then without him (this relates with downforce lvl and car stablitiy in corners), they will use it. if it's not and system working but performances are inconsistent (this relates if system is automatic and not depends on DRS button), they will wait probably belgium.
hardingfv32
hardingfv32
Did not Kimi have radio communications during P2 that is was not working... loss of rear downforce?
Brian
Jackles-UK
hardingfv32 wrote:Did not Kimi have radio communications during P2 that is was not working... loss of rear downforce?
Brian
Pit wall said something along the lines of "the same thing that happened at Silverstone has happened again so loss of rear DF". Points to being unrelated to the F-Duct type system, no idea what it could be mind you! Maybe DRS partly jammed open or something?
Owen.C93
Owen.C93
191
Matt Somers wrote:
Huntresa wrote:Kimi did however run the airbox with the 2 new ducts in it without the stuff connected to the wing.
Which effectively tells us they are creating DF from those ducts via most probably exiting the air through the lower cooling hole. No point running that engine cover / ducts if you have the normal spec there as it will create more drag.
Lets not get ahead of ourselves. Weren't the ducts blocked off during quali/race?
MarkedOne8
MarkedOne8
They could be blocked, but they would still create some drag for nothing.
Here is just basic 'maybe case' explanation for that system - http://www.formula1.com/news/technical/ ... 3/985.html
If this system has nothing to do with DRS system, in case it is passive F-Duct, they still CAN install even the Mercedes style DDRS system.Two systems for same hole in rules.
alogoc
alogoc
-10
THE F2012!
THE CAR THAN WON 2012 WORLD F1 CHAMPIONSHIP WHIT A TILTED ENGINE!
madly
madly
Slightly better photo:
.. and Grosjean's version for comparison:
madly
madly
Alan Permane
Rear wing configuration will run to maximum downforce levels here thanks to the relatively low speed nature of the circuit. As with the rear, maximum downforce is required from the front wing in line with the circuit layout and also to help counter understeer. We will run a new specification of front wing to assist with this.
Neno
Neno
-29
madly wrote:Alan Permane
they say "too much downforce can hurt you on high speed tracks", lucky hungaroring isn't one of them =D>
techF1LES
176
New nose cone:
Huntresa
Huntresa
Thats a reflection right or is taht a bulge?
superdread
superdread
16
Huntresa wrote:Thats a reflection right or is taht a bulge?
That's a quite big bulge, somewhat similar to that on the Marussia. But maybe it's just some sort of measurement device (wouldn't know what it would measure, but stll).
madly
madly
techF1LES wrote:New nose cone:
What's changed. It's "fatter"?
Another view of it:
