Most pec...bizarre aerodynamics thread.
Re: Most pec...bizarre aerodynamics thread.
If you thought that the bottom of the s**t aerodynamic solutions barrel has been scratched I present to you....
The 1969 Cosworth F1 car a.k.a. Cosworth's failed attempt to enter the competition with their own Formula 1 car.
Grid S2, one of the earlier Group C cars.
olefud
olefud
79
nacho wrote:It doesn't make sense for providing grip in corners unless the wings are active and stay perpendicular to ground.
The earliest car aero –not including the road Chrysler- was a vertical wing mounted on the left side of an Indy roadster. The ‘lift’ was vectored into centripetal force. Sorry, can’t find a picture, or even a mention anywhere.
stefan_ wrote:If you thought that the bottom of the s**t aerodynamic solutions barrel has been scratched I present to you....
In fairness to Cosworth, their car wasn't an attempt to use aerodynamics to improve pace, it was an attempt to give traction out of corners - something that cars of the time didn't excel at, hence the 4 wheel drift. If wings hadn't arrived in F1 for a few more years, the 4WD Cosworth might have been developed in to something worthwhile. As it was, aero downforce gave grip without weight and so cut the ground from under the Cosworth car with it's heavy, complicated drivetrain.
xpensive
xpensive
214
xpensive
xpensive
214
Don't know if we had a Sprint car on this thread before, but this Bud's for you!
gavingav1
couple of real lookers
SectorOne
Not really bizarre but Somerfield retweeted it and i found it interesting,
Why the holes on either side?
And why the dip in the diffuser on the sides?
It sort of curves up like you would expect but then drops down to wheel rim height for some reason.
Is it regulation as to why they haven´t run full AoA on the whole width or something else?
The holes on either side are for the exhaust.
Also, those edges were there because of the rear wheels influence. For example, the Jordan 191 only had two large tunnels
SectorOne
thanks, sick image btw, that is one badass diffuser.
Talking about badass diffusers....
FW17
189
This is a pic of a Red Bull show car used in 2009.
Did the piece between the diffuser and beam wing exist up till 2008? I kind of do not remember it being there. This kind of looks like a Jaguar Group C from 1993.
Carmack
That, I belive is a pre-2009 diffuser, with the central 150mm zone on the centerline, that was regulated differently. I don't know the regulations, but all the teams had sort of extended diffuser tunnels.
If it's on a '09 RBR body, then It's another of those mix show cars.
One of the most awkward looking open wheeler ever, the Swift FN09
mep
29
The “piece” there is actually the suspension. It’s a big shroud covering the Tlink, drive shaft and rearward leg of the front lower wishbone. Until 2013 it was common practice to have such covers but the rules changed then to make it much more difficult. It might be that Redbull is the only team which still found a solution by making the covers structural. For the other teams they are just flimsy covers over the actual wishbones.
