McLaren MCL36 Speculation Thread
Re: McLaren MCL36 Speculation Thread
gcdugas wrote:
06 Feb 2022, 16:13
Not so. If you can't understand this via human imagination, then run a simulation via Solid Works or CATIA. I learned this stuff back in the old days when students had to make load bearing towers using thin wooden dowel sections.
Of course you can, the damper works against the spring. The spring is before the pullrod from the dampers perspective, so the force is reacted before it and the load on the pullrod is the tension of the spring supporting the car.
Ergo a pullrod remains a pullrod in both compression and rebound.
I would love for you to show your simulation in Solid Works because I think you're making absolutely basic mistakes here.
Tim.Wright
330
gcdugas wrote:
06 Feb 2022, 16:13
Tim.Wright wrote:
06 Feb 2022, 11:16
Push/pull-rod loads generally never change sign. They do however oscillate about their static load. So in your example of a bump, in the compression cycle the pullroad load increases in tension above it's static weight (+ downforce) load. In the rebound cycle the load reduces to a value less than the staic load but remains in tension.
Solidworks and Catia aren't going to help here. This is a force problem not a kinematic one.
Pullrod load is equal to your wheel load divided by motion ratio. Wheel load can never be negative (limit case is zero when the wheel is physically off the ground).
So, unless your wheels leave the ground and your dampers are hydraulically locked in rebound, your pull rod is always going to be in tension.
An FBD of the upright will illustrate all of this very clearly.
gcdugas
PhillipM wrote:
06 Feb 2022, 17:15
OK, when the length of damper expands during the rebound cycle, what kind of load does that place on the pullrod? Compression or tension? This should be easy....
Innovation over refinement is the prefered path to performance. -- Get rid of the dopey regs in F1
adrianjordan
I really wouldn't read much into the Lego model.
I'm a massive lego fan and the curved shapes of an F1 car are ridiculously hard to replicate using lego!!
Favourite team: McLaren
Tim.Wright
330
gcdugas wrote:
06 Feb 2022, 23:05
It reduces the tension force, but remains in tension.
Stu
gcdugas wrote:
06 Feb 2022, 23:05
PhillipM wrote:
06 Feb 2022, 17:15
The damper/spring do not place a load on the pull-rod that is greater than that placed by the unsprung mass during rebound.
Compare the sizes of the pull-rods (front) and push-rods (rear) of most competitors over the last few years. A pull-rod operates solely in tension (unless the wheel that it is attached to is not in contact with the race-track).
gcdugas wrote:
06 Feb 2022, 23:05
Very easy, the rebound force exterted by the damper against the spring force from the torsion bar reduces the spring force exerted.
Hence the pullrod sees less force from the spring supporting the vehicle. Less. It does not reverse it.
gcdugas
PhillipM wrote:
07 Feb 2022, 00:11
gcdugas wrote:
06 Feb 2022, 23:05
Forget the magnitude of the force for a moment. Answer the question... Is compression or tension exerted upon the pullrod during rebound?
Tension. As I already said.
Tim.Wright
330
Tension...
Same direction as the static load.
NiyolHuayra
NiyolHuayra
I have just seen the Lego leak, my thoughts: I think this only confirms the color scheme nothing more :D (flies away)
bauc
NiyolHuayra wrote:
07 Feb 2022, 12:18
Yeah, there are a ton of people working at Lego who had the design of the Lego model long ago for this, so its just a generic F1 model with the color scheme of Mclaren
BOEING>AIRBUS
BOEING>AIRBUS
Hoping that to be the case 🤞
NiyolHuayra
NiyolHuayra
From 2022 - McLaren Formula 1 Team thread by User: wogx (memberlist.php?mode=viewprofile&u=36832)
Emag
Emag
NiyolHuayra wrote:
07 Feb 2022, 17:30
https://www.wykop.pl/cdn/c3201142/comme ... fnjB41.jpg
Sidepods look like Haas' but I am not sure if they look that way because they are made out of lego pieces, or because the model that McLaren gave them was like that #-o
Developer of F1InsightsHub
