Mercedes W17
Lasssept
118
Re: Mercedes W17
inst omwatw_photography
Re: Mercedes W17
Radiator mounting visible in the 2nd picture.
Beware of T-Rex
Lasssept
118
Re: Mercedes W17
Motorsport Italy
Re: Mercedes W17
Beware of T-Rex
Re: Mercedes W17
It's interesting to see the exposed wheel spokes. I think they trying to promote heat transfer from the wheel rim to the air. The rim supplier this year is OZ Racing (also partnered with RBR).
Beware of T-Rex
Snelbaard
Re: Mercedes W17
Those are actually wheel covers that are just shaped to resemble spokes, they are not the actual spokes themselves.
Re: Mercedes W17
Snelbaard wrote:
13 Feb 2026, 23:39
Hmm, it does look like that now. It still possible that more heat transfer occurs. There is more surface area.
Beware of T-Rex
Re: Mercedes W17
Snelbaard wrote:
13 Feb 2026, 23:39
On second review, I'm not convinced. It looks like a forged wheel. No cover. You can see where it has been chipped down to the bare metal by the wheel gun.
Beware of T-Rex
Gridlock
42
Re: Mercedes W17
You can see the smooth, closed insides of the Mercedes wheels here @ 17:40
Unless you mean unsure whether spokes are metal or just plastic shapes
#58
Brahmal
Brahmal
73
Re: Mercedes W17
Interesting that other teams are doing novel or extreme suspension designs, while Merc is plugging along with the same old stuff
Re: Mercedes W17
Gridlock wrote:
14 Feb 2026, 18:36
https://i.postimg.cc/BQfpkn3Z/Screensho ... -35-24.png
Yes I think the spokes are metal and not plastic shapes. There is no reason to invent plastic spokes. They are heavier than a flat cover.
Beware of T-Rex
Farnborough
Farnborough
152
Re: Mercedes W17
14 Feb 2026, 17:25
Snelbaard wrote:
13 Feb 2026, 23:39
Agree the "spokes" are likely to be metal.
Appears to be anti-seize compound they use to prevent "galling" between nut and wheel materials. Remember Bottas Monaco ?
It's, or feels like, silicone grease + graphite to avoid this eventuality.
Here, looks to be centrifuged out of the joint face.
Re: Mercedes W17
Front wheel rim, also spoked (AMUS pictures).
Beware of T-Rex
SB15
SB15
Re: Mercedes W17
Brahmal wrote:
14 Feb 2026, 18:50
The W15 & W16 ultimately had the suspension geometry that Mercedes would likely carry over for the now W17. They maybe the only team who didn't change the geometry for the last 2 years.
Re: Mercedes W17
It's not all the same. The bottom leg is much further back on the front suspension. the livery lines are also very similar, so the upper rear arm is lower in the 2026 car.
Beware of T-Rex
