vorticism
vorticism
449
It's optional. It can be located in the ES area or the ICE area, or both. The permitted minimum weight limit for the MGUK and PU as a whole varies based on the decision.
saviour stivala
saviour stivala
43
michl420 wrote:
20 Jan 2026, 16:23
Is the MGUK there (in front) mainly for weight distribution reasons or must it be in the surviving cell?
[/qu
MGU-K must be within the survival cell.
Andi76
Andi76
476
michl420 wrote:
20 Jan 2026, 16:23
I actually think that with narrower cars, greater attention is being paid to keeping the CoG low at all costs. This wasn't a top priority for the tanks of recent years, but now it's becoming much more important again. What I'm missing is the oil reservoir and the compressor...could Honda have placed the oil reservoir at the rear like Ferrari did in 2014? In general, it looks like a split turbo design with no compressor and no oil reservoir.
michl420
michl420
Andi76 wrote:
20 Jan 2026, 17:37
michl420 wrote:
20 Jan 2026, 16:23
If they want a low CoG, they should locate the MGUK beside the crankshaft and use the lower part of the fuel tank for fuel.
FW17
189
michl420 wrote:
20 Jan 2026, 17:43
Andi76 wrote:
20 Jan 2026, 17:37
michl420 wrote:
20 Jan 2026, 16:23
Rules state in front of engine and same shaft as the crank
Ashwinv16 wrote:
20 Jan 2026, 07:19
what's the two things sticking out....? I thought it was twin throttle body set-up but like since like eons f1 cars where always individual throlle trumpets wasn't it?
The two "horns" on the upper side are also striking. "The horn-like bulges are necessary because a standardised boost pressure sensor is required so that the FIA can monitor the maximum boost pressure," explains Kakuda. "For demonstration purposes, we mounted it where it is clearly visible."
Beware of T-Rex
mzso
mzso
75
Hoffman900 wrote:
20 Jan 2026, 15:55
I think the rules are clunky and the place to exhibit technology is in endurance racing, not a single seater, sprint formula series.
Even though most people think F1 should be a technological pioneer.
mzso
mzso
75
20 Jan 2026, 20:02
Ashwinv16 wrote:
20 Jan 2026, 07:19
Why the hell do they monitor boost, when there's already fuel flow limit.
BassVirolla
mzso wrote:
20 Jan 2026, 23:30
20 Jan 2026, 20:02
Ashwinv16 wrote:
20 Jan 2026, 07:19
I suppose, to avoid "dieselization" (compression ignition). Why, I don't know, but all the past regs were enforcing spark ignition.
Hoffman900
Hoffman900
243
mzso wrote:
20 Jan 2026, 23:26
Hoffman900 wrote:
20 Jan 2026, 15:55
Who are “most people”?
Technological pioneer but they’ve banned turbo technology that has been around 50 years…
GoranF1
GoranF1
149
Does anyone care to speculate about what is being hidden here?
Beware of T-Rex
Juzh
161
Honda throws cold water on the-race's absurd claims of lacklustre battery tech.
https://global.honda/en/F1/features/202 ... ry/kakuda/
When it comes to the battery, is it fair to think that the performance advantage from the previous PU can be carried over?
“That’s what we believe—and what we hope. Even after the decision to end our activities, battery development continued, not limited to F1 alone. Because of that, it has evolved further, and it’s an area we’re confident in.”
DarkAlman
There seems to be some sort of plenum between the end of the exhaust and the turbo. Perhaps to even out the exhaust pulses before they go to the turbine.
The split turbo concept seems to have carried over, as we can see the turbo air intake at the front the chassis.
The MGU-K mount so far forward is a choice. Curious how that gets connected the transmission? Many decisions seem to be to make the rear of the car as narrow as possible. That may be Newey's influence.
The double air intakes / throttle bodies is another interesting choice. Maybe they want to be able to control each bank of cylinders independantly?
Now I'm wondering if they will be running 2 separate water/air intercoolers, one on either side of the chassis.
saviour stivala
saviour stivala
43
What a load of~wind.
