Sergej
19 Apr 2025, 16:11
Sergej wrote:
19 Apr 2025, 16:03
Car seems good on low fuel...big question mark is race pace.
Without the lockup at last corner we're probably two tenths off to mclaren with mclaren running lower on engine in fp3
spoken too soon I fear :D
Sergej wrote:
19 Apr 2025, 16:15
19 Apr 2025, 16:11
Sergej wrote:
19 Apr 2025, 16:03
Well I did say we were 2 tenths off their lower engine mode... Then they turned it up :mrgreen:
Xyz22
Xyz22
125
19 Apr 2025, 16:22
Sergej wrote:
19 Apr 2025, 16:15
19 Apr 2025, 16:11
They will sandbag on purpose in quali to avoid the dominant car talk.
Sergej
the gap will decrease as temperatures drop, anyway they are not touchable barring drivers' mistakes
pantherxxx
pantherxxx
Well in Bahrein FP3 Verstappen was 1.3 seconds slower than the Mclarens, and then in the qualy only by 0.5 seconds. That's 8 tenths improvement, just would be enough here to fight for the pole.
Cs98
Cs98
pantherxxx wrote:
19 Apr 2025, 16:42
Let's not kid ourselves. The McLaren is ridiculously dominant and will be on pole by a wide margin.
AriaanGert
AriaanGert
McLarens are much quicker, but I am not so sure of them both being in front with a wide margin in quali. The 2 are so close, they will push each other so much that I expect mistakes. We'll see.
pantherxxx
pantherxxx
Cs98 wrote:
19 Apr 2025, 16:43
pantherxxx wrote:
19 Apr 2025, 16:42
Yes but during qualy the asphalt temperature will be 12-14 celsius lower than during FP3. Completely different conditions.
We need more usable downforce. Miami cake tin upgrade & then Imola performance. That will probably bring us into the fight at more circuits but it won't close the gap
venkyhere
43
McLaren in sector1 is untouchable. Sector1 in jeddah used to be a Redbull fortress from 2022. That Japan win from a few weeks ago was indeed a miracle, thanks to a lucky combination of harder compounds chosen by Pirelli and cold weather chosen by nature. I don't think the flexi wing correction in Barcelona or the 'imola upgrades on redbull' is going to do anything to change the status quo. The RB21 doesn't hold a single ace over the MCL39, that car holds all aces in all types of corners, all temperatures, all ride heights.
The 'gulf' is bigger than anyone expected. The European leg of races is going to be a bloodbath.
venkyhere wrote:
19 Apr 2025, 17:37
Red Bull need to make a step in overall downforce level. They have more windtunnel hours than Mclaren. If they can do that, there's no reason that they can't be more competitive. Lots of "if" in that case.
Beware of T-Rex
I don't know if the trend will continue in qualifying when all the PUs are turned up, but Red Bull is very fast on the straights here. At least 5-7km/h over Mclaren and slightly less over Mercedes.
Beware of T-Rex
Paa
19 Apr 2025, 17:46
https://i.postimg.cc/GmH3bxKn/image.png
https://i.postimg.cc/Zn4KZk7w/image.png
I noticed they usually run the PU harder during FPs when there is a new unit installed (but I think only during Friday?). So we might not get the usual improvement this time.
pantherxxx
pantherxxx
venkyhere wrote:
19 Apr 2025, 17:37
Maybe the RB21 doesn’t hold the aces right now, but its biggest ace is potential. The MCL39 might be close to perfection, but that also means it's running out of headroom for improvement—finding another 3–4 tenths gets exponentially harder when you're already near the ceiling. Red Bull, on the other hand, still has clear areas to work on—instability, tyre management, setup sensitivity. If they solve those, the performance jump could be massive.
Sergej
pantherxxx wrote:
19 Apr 2025, 18:46
venkyhere wrote:
19 Apr 2025, 17:37
That's the typical wishful thinking of who is behind.
