Sorry I didn't upload pictures of my Australian GP spec, but this here is the Malaysian GP spec.
Here you can see the new exhaust positioning, and an intake for the condenser, which will be implemented into the car for the Water Blown Diffuser, via a heat exchanger.
Here is my new rear wing, with an intake in the endplates, when the DRS is closed, the airflow feeds into a passive F duct in the central section of the main plane. When it is open, it instead exits through a hole, which is covered by the DRS, as Mercedes do.
New diffuser, with extended upper deck, and now including gurneys above.
Here is the WBD, and the explanation for how it works can be found on the previous post.
