Chene_Mostert wrote:Cold fusion
If I discharge a battery at a rate of 4Mj over 33,33 sec into a variable speed drive, driving a dc motor how much power does the vsd deliver and how much power does the motor convert (assuming 100% efficiency)?
120Kw.
Is this limit defined and measured - yes,
regulation 5,2 and appendix 3
If i now supply an additional 1Mj of energy over 33,3sec to the vsd to drive the electric motor what would the power output of the electric motor now be?
150kw
Is this additional energy source defined -no
Can it be measured if not defined-no
Chene, the output of the electric motor - the mgu-k- is measured and regulatory set at 120kw. It does not matter if I have 1, 5 or 10 undefined energy sources. Next to the fact undefined energy sources are illegal, all the electric energy sources have to pass through the mgu-k which houses the electric motor, at which point the dc will be measured. If you go beyond 120kw, you are running in an illegal mode. If you try to bypass it, your PU is illegal. Either way, there is no regulatory way to run more then 120kw (well, except within the small margin of the 95% efficiency).
For the record, you can run 2 energy sources, mgu-h and the ES, simultanously. However, the combined kw still is not allowed to exceed 120kw.
(als, what do you exactly mean with "vsd"? Hard to keep up with acronyms!)
