McLaren MCL36
Mchamilton
Mchamilton
Re: McLaren MCL36
AeroDynamic wrote:
12 Feb 2022, 15:11
According to ‘Kyle.engineers’ the wing elements toward the end plate must be a render artefact because he cannot see how they would be legal with the rules. But to me, the render looks intentional 🤔
The wing on the actual car is substantially different to the renders
Re: McLaren MCL36
trinidefender wrote:
12 Feb 2022, 16:11
As well as the front being a pullrod it is also a multi link setup with the lower arms connecting to the hub separately instead of as a wishbone.
https://pbs.twimg.com/media/FLYeOmfXMAE ... name=large
Multi-link on the lower arms will change the camber when the wheels are steered.
That might be too finicky for the engineers to set-up so, unless it has massive benefits, I doubt it. :idea:
billamend
billamend
Re: McLaren MCL36
I know nothing about aerodynamics and mechanical engineering, but the first time I saw the car it looked underdeveloped/basic. But it turns out that it has a lot of tricks on its sleeves.
Key hinted that they worked a lot on the mechanics and suspension of the car (because they couldn't work on aerodynamics). I'm very curious to see if they got it right, but I'm hopeful.
DiogoBrand
74
Re: McLaren MCL36
Stu wrote:
12 Feb 2022, 17:41
timbo wrote:
12 Feb 2022, 17:29
12 Feb 2022, 16:11
Oh, this front wing is totally different from the render!
And at the outside it really minimises the effect of the slots at the base of the end-plate. They are maximising outwash here.
What's curious is that they've created all those rules to minimize outwash, but looking at that front wing it seems to me that the outwash may be even more aggressive than last year. I wonder what that tape is for, though. I don't think it manages to hide anything.
NicoS
-2
Re: McLaren MCL36
DiogoBrand wrote:
12 Feb 2022, 19:36
Stu wrote:
12 Feb 2022, 17:41
timbo wrote:
12 Feb 2022, 17:29
What's curious is that they've created all those rules to minimize outwash, but looking at that front wing it seems to bme that the outwash may be even more aggressive than last year. I wonder what that tape is for, though. I don't think it manages to hide anything.
Yes, I think the "technical" "working" "group" have missed the ball totally.
They played on-side, but ball went Leg-side!
I do not think the inefficient rear wing and toy front wing will improve "following" of in front car!
I think it will make more troubles for following!
the EDGE
the EDGE
68
Re: McLaren MCL36
NicoS wrote:
12 Feb 2022, 19:41
DiogoBrand wrote:
12 Feb 2022, 19:36
Stu wrote:
12 Feb 2022, 17:41
simply by removing the overly complicated bargeboards that created immense outwash the FIA have made the cars follow each other better, to what degree is another question
Stu
Re: McLaren MCL36
the EDGE wrote:
12 Feb 2022, 19:49
NicoS wrote:
12 Feb 2022, 19:41
DiogoBrand wrote:
12 Feb 2022, 19:36
I’m really pleased that the barge boards have gone.
Hoffman900
Hoffman900
220
Re: McLaren MCL36
Stu wrote:
12 Feb 2022, 19:51
the EDGE wrote:
12 Feb 2022, 19:49
NicoS wrote:
12 Feb 2022, 19:41
Agreed.
FittingMechanics
FittingMechanics
Re: McLaren MCL36
Can we assume that low speed problems of MCL36 were suspension related? Given that the suspensions were simplified, does this bode well for McLaren? If they were losing time due to it.
Quite happy with the car. Hopefully it is fast :).
SmallSoldier
SmallSoldier
486
Re: McLaren MCL36
Xero wrote:
12 Feb 2022, 14:27
https://cullenfc.co.uk/xero/images/McLaren%202022c.jpg
Upscaled and enhanced look at the rear;
- Double element beam wing like the Aston.
- Lots of detail coming off the rear wheel cake tin.
- Some interesting details attached to the diffuser wall, didn't expect to see that.
- Deep spoon shape on the rear wing, good angle here to show just how much.
- Diffuser blocked off as expected.
Thanks!
SmallSoldier
SmallSoldier
486
Re: McLaren MCL36
Stu wrote:
12 Feb 2022, 15:06
SmallSoldier wrote:
11 Feb 2022, 22:39
AeroDynamic wrote:
11 Feb 2022, 22:28
Look at the gap between the rear face of the top front wing planes to the front face of the front tyres. The gap between the Aston Martin wing and its front tyres is bigger than that of the McLaren. Maybe the nose is shorter? or.. the front wing is bigger in depth?
https://i.imgur.com/wnZrd7I.jpg
Since the distance between axles is fixed, if the front wing is closer to the front tires, the rear will be farther away (and vice versa)
(Not to scale):
https://i.imgur.com/kKO8CMX.jpg
The wheelbase is not fixed. There are upper limits (3600mm), but they can go shorter. I think that there is also a lower limit, but need to check.
You are right! I am just making the wrong assumption that every team will have maximized the wheelbase 🧐
Mchamilton
Mchamilton
Re: McLaren MCL36
NicoS wrote:
12 Feb 2022, 19:41
DiogoBrand wrote:
12 Feb 2022, 19:36
Stu wrote:
12 Feb 2022, 17:41
You do realise they had access to the immense computing power at AWS and were able to run 2 car simulations to actually check their theory in practice. Im sure they know a bit better than us all on here.
NicoS
-2
Re: McLaren MCL36
Hoffman900 wrote:
12 Feb 2022, 19:52
Stu wrote:
12 Feb 2022, 19:51
the EDGE wrote:
12 Feb 2022, 19:49
Agreed.
Initial barge board were good, like deflectors. then it just became total overkill. I mean drivers took the risk of loosing a leg just exiting the cockpit! :lol:
DiogoBrand
74
Re: McLaren MCL36
Mchamilton wrote:
12 Feb 2022, 20:03
NicoS wrote:
12 Feb 2022, 19:41
DiogoBrand wrote:
12 Feb 2022, 19:36
I woulnd't go to the extreme of saying they missed the ball completely, if there is a problem it's just a matter of tweaking the regulations for the next seasons.
But having the computing power from AWS means little when they can't predict what solutions the teams may come up with.
Re: McLaren MCL36
DiogoBrand wrote:
12 Feb 2022, 19:36
Stu wrote:
12 Feb 2022, 17:41
timbo wrote:
12 Feb 2022, 17:29
This guy disagrees and says this front wing is almost fully inwashy
And these CFD tend to confirm it viewtopic.php?t=28657
