Richard
Richard
Re: A shameless thread for the enginephiles
http://en.wikipedia.org/wiki/Diesel_engine#History
At Augsburg, on August 10, 1893, Rudolf Diesel's prime model, a single 10-foot (3.0 m) iron cylinder with a flywheel at its base, ran on its own power for the first time. Diesel spent two more years making improvements and in 1896 demonstrated another model with a theoretical efficiency of 75%
670
Ackroyd Stuart seems to have made a real 'diesel' engine before Diesel did
but as AS's company were already in large-scale production of his hot-bulb engine, they didn't see any need for change
hundreds of thousands of these cheap and simple hot-bulb engines (otherwise known as semi-diesels) were made after Diesel
all engines have rights, don't they !
zonk
zonk
69
who said diesel is soulless?
[youtube]http://www.youtube.com/watch?v=nbNWcog2gx4[/youtube]
[youtube]http://www.youtube.com/watch?v=fcDHdhn4Rgc[/youtube]
Blanchimont
Blanchimont
214
richard_leeds wrote:http://en.wikipedia.org/wiki/Diesel_engine#History
It says theoretical efficiency of 75%.
The overall measured efficiency in 1897 was 26,2%! Not that bad, i would say.
http://www.deutsches-museum.de/sammlung ... otor-1897/
Cold Fussion
Cold Fussion
95
Can the theoretical thermal efficiency even reach 75%? I thought the limits of the diesel and otto cycle was ~60% efficiency.
670
is that the 'true' Diesel cycle (heat added at constant volume) that could not be made to work by Diesel or anyone ?
or the Diesel cycle that Diesel used and diesel engines still use by design or accident (heat added at constant pressure or nearly so) ?
FoxHound
55
richard_leeds wrote:Especially for foxhound, this is where it all began.
Engineers will appreciate the 75% thermal efficiency.
Other forums are available for vroom-vroom fanboys
Some high grade moderation there richard. Real quality stuff, top notch.
JET set
zonk
zonk
69
Pipe porn six cylinder two stroke Kohler engine originally meant for a military drone!
FoxHound
55
Nice find Zonk.
Found a video to go with the pictures.
[youtube]http://www.youtube.com/watch?v=5svXFNmM5cU[/youtube]
[youtube]http://www.youtube.com/watch?v=CR7E-D7i0m0[/youtube]
JET set
flynfrog
shut up and take my money. I have always wanted to build a mercury optimax V6 Locost
Admittedly not a pretty engine but V6 two stroke
andylaurence
123
I was involved in a project to use a V8 Evinrude two-stroke engine in the back of a sprint/hillclimb car a couple of years ago. I've heard nothing of it recently, so I suspect it's run out of budget. The engine weighed just 80kg and could put out 500bhp, yet cost peanuts to buy. The plan was to run it with a dual CVT system and no differential. 8 silencers helped offset the low weight!
zonk
zonk
69
[youtube]http://www.youtube.com/watch?v=lRKeuHyI0lw[/youtube]
if an V8 isn't enough - supercharge it!!!
xpensive
xpensive
214
We have had images of the world's smallest V12 on the forum before, but this 12 cc pushrod is so cool;
FW17
185
http://dazusfb7pt2uv.cloudfront.net/aca ... YP606R.jpg
http://outboardpowerheads.com/813043R97.jpg
Always been fascinated by 2 stroke, always thought their abandonment was more political than anything else
On that mercury 2 stroke how is the exhaust routed?
Their block has such high bore (almost like an f1 engine)
Here is a link to a Lola fitted with Mercury F1 V6
http://www.lolaheritage.co.uk/history/r ... 294_01.htm
Sombrero
Sombrero
126
