Simplifying, and reducing costs are admirable goals, but would love to see weight reduction also.wuzak wrote:Dumping the MGUH is the most likely scenario to "simplify" the power units, while keeping the MGUK.
Without the MGUH they could then reduce the size of the ES from 4MJ to 2MJ. This would help reduce weight, as would leaving the MGUH off (~10kg for an MGU)...
How much weight would likely be saved if the size of the ES is reduced?
May there be other weight savings besides MGU-H & ES size, as a result of this cost reduction, simplifying exercise?
