McLaren MCL33
Re: McLaren MCL33
Tidy little car. =D>
Needs stegosaurus fins to put the icing on the cake.
Re: McLaren MCL33
PlatinumZealot wrote:
27 Feb 2018, 01:38
There should be a few down the back of the halo behind where they currently have the winglets/spoilers unless they've ditched them since xmas.
Re: McLaren MCL33
Sieper wrote:
27 Feb 2018, 01:21
Yes I do, but there is something sticking up and between the two arms of the split wishbone, it has a Jagged, torn edge, brown colered specs where it has torn. A cm or two back also something White is torn where it seems the Outer layer of material has ripped off.
...and the perfectly clean, straight line of the wishbone besides it shows you it's not the wishbone, but more likely just the gearbox housing you're seeing or cover with a bit of gravel rash.
The fact there's a wheel on it should give you a clue too. You're having posts deleted because this belongs in the testing thread, not here.
f1rules
f1rules
623
Re: McLaren MCL33
compared last years rb
Re: McLaren MCL33
Aero testing this morning.
Re: McLaren MCL33
Re: McLaren MCL33
Via AMuS
Via @F1debrief
Egresi Tamás
Egresi Tamás
Re: McLaren MCL33
Burns
oetger
Re: McLaren MCL33
Re: McLaren MCL33
Outlet at the end - just behind where Renault is written.
santos
santos
Re: McLaren MCL33
Is that burnt? :wtf:
Godius
186
Re: McLaren MCL33
Re: McLaren MCL33
Good look at the Halo Fairing with Flowviz:
[media]https://twitter.com/AlbertFabrega/statu ... 3778434050[/media]
Lucky
Lucky
157
Re: McLaren MCL33
cyclon
-2
Re: McLaren MCL33
A bit scary .....
but if you check where pit crew blowing air it's easily understandable that they know about it!
That's why the small inlets...
I loved the iconic McLaren-Honda
But most of all i love McLaren . After all first contact made with M23 that had a Ford Cosworth PU
