What is Cl(f) in the above? The front lift of the rear wing part??
Thomas
I am so sorry! I had great expectations
Thanks for the update; good to hear that you found the mistake and we know that nobody else’s results will have the same issue. Now let’s see how those cars perform!!!
Yes, no problem to share an error I made while manually editing the forceCoeff file, I hope it can be useful for the other teams.
Hi, I use Solidworks. I model the whole car as a single part, but as a multybody. Since the car derived from an old project, I need to use some "cut" ("divide") at the end, but if you start from scratch, and you use in the correct way the option to "join solids" when you create it, you should be able to obtain automatically the components.k.ko100v wrote: ↑20 Aug 2019, 13:58Hi guys,
I am struggle to start the modeling.
Is there anyone who is using SolidWorks, to open a chat with. I just need some hints and tips regarding how to save the different parts, how to assemble them, and how to coordinate them.
I read the rules from the mantium web page but still cannot understand from where to begin with and how to deal with the files.
Thanks in advance,
Krasen
Here is what I have, just to make sure I did not miss anything:
I also use Solidworks and model the entire car as one single part. Then I use the "split" feature to create the different sections as per the rules. I find this easiest as many features interact with others or rely on others as a reference. It does however become a problem when editing a feature as many others can be affected.k.ko100v wrote: ↑20 Aug 2019, 13:58Hi guys,
Thanks in advance,
Krasen
LVDH wrote: ↑20 Aug 2019, 15:25Here is what I have, just to make sure I did not miss anything:
- Team name--------------------CAD received
- Baltic-----------------------------------y
- CAEdevice----------------------------y
- CCE------------------------------------y
- GGB------------------------------------y
- Idadox----------------------------------y
- JJR Racing----------------------------n
- MercuryMotosport-------------------y
- OK Racing Team---------------------y
- Pure Power Racing------------------n
- TalnoRacing---------------------------y
- Team Koldskaal-----------------------y
- Variante---------------------------------y
- WBRacing------------------------------y
First simulations are running. Tomorrow I can probably show the images of all cars.
- Wind Wizards Incorporated--------n
