McLaren MCL39
f1rules
f1rules
635
Re: McLaren MCL39
Wow amazing pics here
https://www.motorsport-magazin.com/form ... 532,0.html
here another picture of the layout
Junaid #JB17
@JunaidSamodien_
It's been a morning of staring at close-ups of the 2025 cars, and yeah, I am blown away by the detail. Pictured below is a McLaren front suspension arm, which is so beautifully sculptured.
PHOTO CREDIT: Motorsport Magazin.
De Wet
Re: McLaren MCL39
The detail on this car is insane. What a Work of Art. =D> =D>
Mattchu
65
Re: McLaren MCL39
Fred wrote:
17 Mar 2025, 03:37
Is there a vent in the floor here near the bib? I know during testing they spoke about there being a hidden vent in the floor for Mercedes, which seemed to be the case given they had a fan down there.
If you mean the section that`s a little bit darker, it`s not, you can see the weave. The sculpting here is beautiful, though I`m surprised they don`t smooth out the upright rectangular section in the bow.
Re: McLaren MCL39
Most teams have had bib vents since beginning of '22.
240
Re: McLaren MCL39
That upper rear arm seems like a flow straightener for the entrance to the floor. Its closeness to the floor is for purely aero reasons.
The other arms upstream also act to break up and redirect upwash from the front wing wake and leave straighter cleaner air into the throat of the floor.
A more efficient floor goes a long way for wider range of close to peak downforce.
The efficiency is also less sensitive to ground speed as with increases of speed, the upwash coming of the front wing changes in intensity.
Breaking the upwash and sending air downstream in a straighter manner is beneficial.
Farnborough
Farnborough
152
Re: McLaren MCL39
ing. wrote:
10 Mar 2025, 19:27
mwillems wrote:
08 Mar 2025, 22:02
There definitely have been many silver bullets in F1. Double diffusers, blown exhaust etc
But I'm not sure what you are arguing about, he's suggesting that if you can get the car to remain a certain distance from the tarmac more consistently without getting towards the jacking and having a good feel then isn't that a win? Even a tenth in this formula will make a big difference.
What was it that he said that was inaccurate? I don't mean to be rude, at all, but this really feels like you are arguing against points that only yourself has put up.
Perhaps I'm being dim, but the conversation was that it looks to have more anti dive characteristics. Then 3 people came along and argued otherwise on the basis that the concept of there being too much anti dive seemingly meant the Mclaren couldn't have more anti dive, and now it turns it, it likely does. Are you suggesting it doesn't have more Anti Dive or you don't believe it because it is too much?
How much antidive does Mclaren have on a scale of 0 to 100% that they could produce?
Wache never suggested that the amount of anti dive was the issue. He said that this year it is very high. He then noted that not only is it higher, but they used geometries to achieve this that are also providing better airflow, with a potential consequence being that it could impact the weight of these parts or there might be technical issues down the line due to the forces at play in the suspension.
Seemingly Mclaren thought more was better.
As has been discussed and demonstrated quite conclusively in the various threads, the arrangement of deeply angled upper and LOWER front wishbones started by RBR in 2022 was for predominantly aero benefit reasons and while this does provide some anti-dive effect, this is relatively small and definitely not even close to what can be achieved by angling the lower wishbones upward at the rear, for example.
In other words, the wishbone pick-ups were sited to benefit aero while (possibly) maintaining a typical (based on team standard practices) anti-dive effect, whatever that may be, considering CG location, etc.
In the case of MCL39 and Wache’s comments, the fact that the upper wishbones’ aft leg pick-up points were dropped as much as they were—and with, presumably, the lower WB angle remaining the same for lack of possibility to drop these further, i.e. they’re at the lower edges of the chassis—this will have in effect increased the anti-dive effect due to the increase in height of instant center point. It could be that, in Wache’s opinion, this increased amount of anti-dive is too much or beyond what he thinks is acceptable.
Also, because Wache mentioned ‘kinematics’ as a concern, this could be an allusion to the fact that with such an extreme angle to the pivot axis of the upper WB, the arc prescribed by the WB outer point (top of the upright) is akin to that of a ‘leading arm’ suspension link, causing the top of the upright to lean aft on compression and so increasing caster angle and kingpin inclination, and possibly steer angle. How much this is an issue will only be borne out by the car’s results.
This element was intriguing me, and seeing your view on it too then gave more reason to consider what COULD be used here.
This "Rob explains: “It’s important to have an open-minded approach to everything because cars are always different. They evolve, and your understanding of what you need to do to make the car go quicker changes. Most ideas aren't new, they're a kind of regurgitation of a previous one. " from recent McL interview adds to this view, in my opinion.
Specifically that arrangement of the two rear legs of front wishbones and their convergence. Ultimately the closer the two chassis points come to each other the more it acts as the leading link you've described.
With that top one at such inclination, the side view of wheel spindle will move backwards in arc through travel from maximum extension to maximum compression. Unless somehow corrected. OR made use of as attribute.
With the steering arm "planar" in pair with the lower of the two wishbones, the steering trackrod passing both nominal kingpin position to ultimately sit outside AND passing the same nominal kingpin in going from rear to in front of it, then that movement you've noted of top kingpin moving backwards as the assembly rises, that SHOULD bring a change of toe geometry increasing as the suspension drops (chassis lifts) that's if left uncorrected OR designed in to do so.
IF the toe in was set to an absolute minimum at maximum suspension setting (full aero load at terminal velocity, or in that region) the accumulated more toe in as front of chassis came up, then it would provide such toe change as DAS was designed to facilitate, but under load conditions. Obviously reducing scrub at near zero, to increasing response at anything less than full compression via raising that toe influence.
How could that be used in real driving scenario ? That leading link type /like geometry should have some element of chassis lifting (by brake torque rotating the assembly downward) as its loosing it's ability over two "conventional " equal and parallel type wishbone arrangement thats more typical.
With the car running flat out, at maximum suspension compression, you'd get v-low toe in, scrub and "softened" steering response to command, all desirable in that scenario. Hard brake application, decaying aero load and lift from brake torque would bring a increased toe in "graduation " to bring much more agility to chassis turn in response.
This is something in the way of independent from "pure" anti dive geometry and kinetics.
With something of a vernier adjustment facility on outer track rod end, it could also be finitely adjusted for accumulation characteristics from track to track, based on target setup and further driver feel.
Effectively DAS by another thinking and implementation, needing no bespoke input and control system to be designed.
michl420
michl420
Re: McLaren MCL39
You think obviously very deep into it and explain it very well. But you oversee that the steering rod is at the level of the lower wishbone "plane". So it is on a fix point of (your) twisting steering axle.
The idea would work with the steering arm mounted outboard in some vertical distance from the lower wishbone, maybe in the middle between the two wishbones.
This is my theoretical view.
But steering and suspension geometry is so complex (at least for me), maybe you are spot on.
On the subject:
https://pbs.twimg.com/media/Gl6v0NiagAA ... name=large
SmallSoldier
SmallSoldier
488
Re: McLaren MCL39
Nice detail of the front suspension
Via: @xavigazquez
_cerber1
301
Re: McLaren MCL39
@LuisFeF1
ispano6
164
Re: McLaren MCL39
Fred wrote:
17 Mar 2025, 03:37
f1rules wrote:
16 Mar 2025, 12:23
Aero porn from Xavier once again @xavigazquez
https://pbs.twimg.com/media/GmJevARagAAxzUm.jpg
The car looks absolute amazing. Gaining 15 secs and 25 on russell and leclerc on inters after the track started to dry, absolute amazing how this car manage tire wear. There is no doubt the car is incredible well balanced with a very stable aero platform, but i cannot help think other areas come into play. Amus mentioned friday, that during testing mcl always tried to hide when wheels came of in the pits, especially when the wheel was removed, and they had to work on underneath the shield/cover. Now they managed to get a picture of it friday in Australia. And it obvious McL put ALOT of attention into this. Combined with russelss comment about mclaren doing something special with its tires, and how mclaren today kept the inters alive. Could suggest something is going on, other then a very good well balanced car.
This answer to Dr-obbs on twitter i find very interesting and plausible. And if it is the case, we will know soon, cause the other teams will be very vocal about it
@the_zb_
"This is my working theory @dr_obbs We saw the very intricate routing on the front brake ducts of the McLaren. As far as I can tell, that’s more specialized than any other team right now. I think they’ve figured out a clever way to use this for more precise and beneficial thermal management of the tires than everyone else so far. George’s comments after quali concerning McLaren “doing something with their tires” seem on point. This makes sense in light of the fact that under Parc fermè rules, they will also be allowed to make an adjustment to this configuration once there’s a “change of conditions” declared. This area falls into the changeable cooling and thermal management relaxation of Parc Fermé rules when conditions change. My hunch is they’ve figured out a way to better tune their tire thermal characteristics with this mechanism, and in conjunction with that ability they’ve also managed to really refine their suspension’s use of the mechanical grip available without tire temp issues. That’s my current theory as to what they’ve done differently."
https://pbs.twimg.com/media/Gl56rc2WIAAabnL.png
Is there a vent in the floor here near the bib? I know during testing they spoke about there being a hidden vent in the floor for Mercedes, which seemed to be the case given they had a fan down there. However, I hadn’t actually seen any floor vents until now. Is this a new thing this year? It’ll be interesting to see this angle for all the cars now to determine if it’s a McLaren thing, Mercedes-engine thing, or if everyone is doing this.
Completely agree with the brake drums. I have no clue what’s going on with them or how to interpret them, but they do seem to be able to heat up their tyres quickly while also keeping a lot more life in the tyres than anyone else. To me, that’d mean the car must have a very wide operating window. Typically you’d expect a car that heats up tyres quickly to also burn through them quickly, but having a large operating window would help keep them alive longer while making it easier to get them into the optimal operating range. It makes sense that these brake drums would help broaden the operating window, although whether or not that’s actually the case we don’t know. We don’t know how advanced others are in this area, and frankly even if we saw this for the other cars I’d have no clue how to interpret the level of development. It does go to show how a lot of the development on an F1 car is unseen though.
A fairly decent explanation can be found here: https://racingnews365.com/new-mclaren-t ... -f1-rivals
The complex assembly of the inner drum fits perfectly with the unusual geometry of the front suspension. The upper wishbone is positioned even further back with its rear attachment point, certainly a refined aerodynamic modification for 2025.
The inner drums of the front brakes have been taken to the extreme for optimum aerodynamic performance. This applies not only to drag, but also to precise load distribution.
The complexity of the drums, combined with the front suspension's unconventional geometry, highlights two distinctive elements of the car.
On the one hand, chief designer Rob Marshall tried to attain the best dynamic behaviour by making the front suspension concept more extreme, also taking into account all the possible critical issues that can arise from an extreme concept.
McLaren was not afraid to take a gamble. However, on the other hand, it has created some characteristics - such as the position of the track rod and the lower wishbone - which allow to mitigate the effects of a front axle that is too rigid.
At the same time, the position and profile of the individual element fairings on the suspension work in synergy with the brake ducts, for precise management of the air flow around the front wheels.
.poz
.poz
Re: McLaren MCL39
f1rules wrote:
16 Mar 2025, 12:23
@the_zb_
the advanced temperature management on the front axe may explain why Mclaren adopted an extreme anti-dive setup
someone from RB said that on some tracks it will be impossible for Mclaren to manage front-rear temperature balance... maybe this system solves the issue
trinidefender
trinidefender
318
Re: McLaren MCL39
.poz wrote:
19 Mar 2025, 19:59
f1rules wrote:
16 Mar 2025, 12:23
@the_zb_
Mclaren doesn’t have an extreme anti-dive setup.
SilviuAgo
151
Re: McLaren MCL39
RW config for Shanghai, tks to Albert photos:
JoeE
JoeE
Re: McLaren MCL39
SmallSoldier wrote:
18 Mar 2025, 19:18
https://i.imgur.com/H98BsQN.jpg
Via: @xavigazquez
Anyone enlighten me to what they 2 spined items are, one green and one black?
Farnborough
Farnborough
152
Re: McLaren MCL39
They are the housing for Torsion bar springs, one for each side suspension.
The bar is located, via the splines, to have it static end "fixed" to the chassis, the other set of splines visible further inside will be attached to the pull rod tension rod from wheel hub.
The spring then provided by twisting that torsion bar to give its support in suspension. They can easily swap the bars for different spec to change spring rate. These don't appear to be fitted in that image, yet to be installed in build phase of car assembly.
