2026 Mercedes-AMG Petronas F1 Team
f1isgood
f1isgood
Re: 2026 Mercedes-AMG Petronas F1 Team
Chuckjr wrote:
11 Feb 2026, 22:05
Too bad all the compression hype has resulted this. Clearly Merc have moved to full "play it down" mode rather than a calm confidence. I expect this kind of approach to the media the rest of testing, and they won't show real speed till Q2/Q3 in Oz.
Yep, they are simply running in detuned mode so that they can try to sell the FIA a detuned image that they are really "weak".
WardenOfTheNorth
Rikhart wrote:
11 Feb 2026, 12:55
CHT wrote:
11 Feb 2026, 12:49
Rikhart wrote:
11 Feb 2026, 12:32
Because the rule says it can never be above 16.
At ambient temperature yes, but when engine is operating at peak temp, compression may change and different engines may have different peak temp.
No, the rule does not say at ambient temp, it says it may never be higher than 16... It's only the test that says ambient temp.
The rules specify how they will define compression ratio using a test and that test specifies ambient temperature.
Therefore, according to the wording of the rules, the compression ratio may never exceed 16:1 - as defined within the rules, ie: at ambient temperature.
The rules, currently, do not specify a test for operating temperature. Therefore the Mercedes ICE conforms to the rules.
"From success, you learn absolutely nothing. From failure and setbacks, conclusions can be drawn." - Niki Lauda
WardenOfTheNorth
f1isgood wrote:
11 Feb 2026, 22:24
Chuckjr wrote:
11 Feb 2026, 22:05
Won't work. The FIA will benchmark the PU's on a dyno.
OverheatedTurbo
OverheatedTurbo
Car seems to be struggling with the track temperatures again according to driver’s feedback. Not a good sign for the team to be grappling with this issue for the 3rd year in a row. #-o
upsidedowntoast
upsidedowntoast
Everyone seems so convinced that they're sandbagging again (probably 2014 trauma) but I don't think so. Mclaren have the exact same engine and they are doing fine. Not just talking about lap times, but their unreliability in hot weather. The fact that they've carried over this issue into a new reg set is very not good.
Maybe this was just a little oopsie and tomorrow we'll see them doing ok, maybe this speaks to more serious flaws within their design philosophy (e.g. chasing peak performance but in a narrow operating window that makes it very sensitive and fiddly in real life conditions).
FittingMechanics
FittingMechanics
upsidedowntoast wrote:
12 Feb 2026, 02:31
I agree. Mercedes was good at cold weather for couple of years now, it's not unreasonable to think they were once again good in cold weather (Barcelona) but that they struggle in hot weather (Bahrain).
But Toto will obviously try to sandbag the engine. If I was in charge I would put all Mercedes powered teams on a weaker PU mode.
Farnborough
Farnborough
152
FittingMechanics wrote:
12 Feb 2026, 09:09
12 Feb 2026, 02:31
There's already an update .... a small patch of carpet (Axminster I believe) to fix on floor underneath throttle pedal ;)
"Rumour" has it that Toto was seen sticking them to each car using MB PU and preventing full throttle opening.
Warning, this maybe just made up :lol:
Lasssept
122
Lasssept
122
Emag
Emag
137
Lasssept wrote:
12 Feb 2026, 10:39
They tried to recharge like RedBull does and burned a fuse :lol:
Developer of F1InsightsHub
SB15
SB15
Emag wrote:
12 Feb 2026, 11:17
Lasssept wrote:
12 Feb 2026, 10:39
or...
venkyhere
43
Farnborough wrote:
12 Feb 2026, 09:16
12 Feb 2026, 09:09
12 Feb 2026, 02:31
https://x.com/MV33Racing/status/2021609 ... 36/photo/1
zibby43
zibby43
Not a great test so far.
basti313
basti313
32
f1isgood wrote:
11 Feb 2026, 22:24
Yes. Looks like...suddenly the RedBull is the strongest engine... #-o
WardenOfTheNorth wrote:
11 Feb 2026, 22:26
And a dyno is free of "modes"?
First of all, if there is a "trick", it is an efficiency trick. They can use it for peak power or better...for efficiency. If they use it for efficiency nothing one could use to attack them will show up on a dyno.
12 Feb 2026, 02:31
GPS data shows that the Merc engines are all lower on power. The McLaren was perfectly balanced, again a super easy to drive car. No miracle that they showed superb long runs. Has nothing to do with the engine.
Don`t russel the hamster!
Lasssept
122
