Williams FW33
djos
115
Re: Williams FW33
Byronrhys wrote:
ringo wrote:this livery looks too dead.
The dark gothic emo thing doesn't work for something as lively as F1. You want to convey an energetic feeling.
I hope the car is bright blue gold red and white.
That would be stunning.
So basically you want this? Image
Yes please! 8)
"In downforce we trust"
HampusA
Re: Williams FW33
I think the sponsors will decide what colour scheme they will go with.
Is it the same sponors as last year? If so then i don´t expect the base paint to be changed much.
The truth will come out...
andrew
andrew
Location: Aberdeen, Scotland - WhiteBlue Country (not the region)
Re: Williams FW33
RBS was the main sponsor last year. They are not around this year as the bank is, well, erm how do I put it? Skint!
zgred
Re: Williams FW33
raymondu999
Re: Williams FW33
Is it just me, or does the Williams packaging actually not look like it's anything special, just that they moved the rear wheels further rearwards so that the floor extended more towards the back from the sidepods termination? :roll:
失败者找理由,成功者找方法
King Six
King Six
Re: Williams FW33
The sidepods round into each other, never seen that before. The gearbox is tiny. The rear suspension supports are on the pylon of the wing. I've never seen any of that before. It's very unique
I still don't know how they're managing their heat exhaustion with that rear end. Where is all the hot air going? Compare their rear end to Red Bull's, and even they have a massive exhaust outlet for the heat.
Williams are running KERS and such too. But I think that's all based around the splitter/plough which is why it's much bigger than most others, but the cooling for this car still baffles me.
I think the livery for this car is too dark to do it justice in terms of how unique it is. Hopefully the real deal is much different.
tommylommykins
tommylommykins
-1
Re: Williams FW33
I think the sidepod heat exhausts are visible in this picture, right at the very, very bottom. That's very different to where Red Bull gets rid of their heat.
mep
29
Re: Williams FW33
Image[/quote]
This looks really funny.
Never seen a F1 car that looks like this before.
Is this rounded bodywork even good for drag?
If this fat area is not there it would actually look really good.
What are they hidding below it?
Is the engine that big?
tommylommykins
tommylommykins
-1
Re: Williams FW33
IIRC, the engine is the last thing before the gearbox, as you go backwards? If so, then that bulge has to be the engine. All the teams' cars have to have an engine, so that lump probably exists in all of the other cars.
I'd guess that the only reason that it is so noticeable on this car is because Williams have done such a good job of shrinking the gearbox, and decided to put their sidepod exhausts right down at the bottom of the car, instead of in between the two wings it the back, like the Red Bull did last year.
Formula None
Formula None
Re: Williams FW33
mep wrote: Is this rounded bodywork even good for drag?
I assume the truncated rear bodywork is meant to set up a low pressure zone directly behind it and ahead of the rear wings, to help pull more air through that area. Simply having the bodywork taper (as Red Bull do on the lower portion of there sidepods) would not be able to set up such an extreme pressure differential as what the Williams can. More drag, but that void will want to pull a lot of air around the engine cover and hence through the RW endplates. That's my guess.
Formula None
Formula None
Re: Williams FW33
An illustration of the idea:
(Thanks zgred for posting the pic)
FW17
171
Re: Williams FW33
zgred wrote:Image
Willaims has an option of lowering the beam wing of the rear wing assembly because of the gearbox.
Will this be an advantage? Is this be legal?
humble sabot
27
Re: Williams FW33
Also notice the current trend of putting the oil cooler on top of the bellhousing/gearbox this goes some way to explain the chunkiness on a few cars in that area. Mclaren last year especially.
My impression is that having the engine compartment exhaust riught under the beamwing like that it gets energized by both that and the diffuser so some extraction speed is generated.
(apologies for crud grammar)
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
roadie
39
Re: Williams FW33
Yep, there's a cooling outlet either side of the rear crash structure, just above the diffuser and below the beam wing. It's fairly obvious from the rear shot. In the image within the post quoted
tommylommykins wrote:I think the sidepod heat exhausts are visible in this picture, right at the very, very bottom. That's very different to where Red Bull gets rid of their heat.
Onch
Re: Williams FW33
FrukostScones wrote:Image
No sure if it is some sort of visual effect from the lens or so, but in that pic there seems to be a *massive* amount of toe-in at the rear... :wtf:
