2025 Aston Martin | Aramco F1 Team
Re: 2025 Aston Martin | Aramco F1 Team
diffuser wrote:
23 May 2025, 14:02
23 May 2025, 13:13
diffuser wrote:
23 May 2025, 12:52
https://i.ibb.co/NgxKSWw8/20250523-064536.jpg
They've definitely taken the new rear wing edge approach to this new rear wing.
Thicker LE at the corners probably for increased df stability at cost of efficiency? Nobody else does this. Could be to do with AMR correlation issues?
LE ?
leading edge, the endplate corner area leading edges are so thick compared to any other team
FNTC
FNTC
Stroll out for the rest of Fp1 they say on Sky. Needs to change gearbox, floor, etc.
Mansell89
Mansell89
This team can never seriously have WCC ambitions until they remove this obvious weak spot from the team. Even Lawrence at this point must know.
23 May 2025, 14:03
diffuser wrote:
23 May 2025, 14:02
23 May 2025, 13:13
LE ?
That's not thicker, that's curved upwards. They want more air to go under the wing, for whatever reason.
-wkst-
-wkst-
Mansell89 wrote:
23 May 2025, 14:06
Driver did a bad job, engineer too. Told him too late about LEC, but in the end there are mirrors… :roll:
mvfad
-1
Something has changed recently in the way things are run internally at Aston Martin in preparation for a GP. Drugovich has been doing simulator testing on Fridays before going to the GP as a reserve driver. Maybe the official simulator driver is busy, but this thing (Drugovich in the simulator on fridays) has not happened for the last 2 years.
SSJ4
SSJ4
32
Pace better than expected. I know it’s only free practice, but better than I thought it would be
NAPI10
NAPI10
SSJ4 wrote:
23 May 2025, 17:33
Track position is everything in Monaco. Alonso can have a great race if he can re-produce something similar to Imola.
Having said that ,AMR25 is supposedly struggles managing slow corners. Anything in Top 10 is a bonus here.
TyreSlip
TyreSlip
NAPI10 wrote:
23 May 2025, 17:47
SSJ4 wrote:
23 May 2025, 17:33
Yes, the FP times mean absolutely nothing right now. I would be ecstatic to see a top 10 qualifying.
NAPI10 wrote:
23 May 2025, 17:47
SSJ4 wrote:
23 May 2025, 17:33
Tires aren't gonna be a problem with the forced two stopper. Slow pit stops will be the bigger problem to avoid. It's gonna take sub 1:11 to make it into Q3.
There is still the analysis of the data to come up with the best setup for tomorrow.
zoroastar
BassVirolla wrote:
23 May 2025, 10:19
Nikosar wrote:
23 May 2025, 09:37
The mandatory new two-stop rule will bring some fun this Sunday
Two stops or three dry sets?
Not the same with a red flag...
i believe its the latter. they must use 3 sets of dry tires, and 2 different types.
mvfad
-1
Alonso must be desperate to score points.
Finishing the season with fewer points than Stroll would be a huge stain on his career lol :lol:
Nikosar
Nikosar
Grid penalty and penalty point for Lance, -1 grid position and -1 point
FNTC
FNTC
zoroastar wrote:
23 May 2025, 18:12
BassVirolla wrote:
23 May 2025, 10:19
Nikosar wrote:
23 May 2025, 09:37
"Following recent discussions in the F1 Commission, a specific requirement for the Monaco GP has been approved mandating the use of at least three sets of tyres in the race, with a minimum of two different tyre compounds to be used if it's a dry race."
https://www.skysports.com/f1/news/12433 ... rt-council
So they can use the same compound of tire twice.
zoroastar wrote:
23 May 2025, 18:12
BassVirolla wrote:
23 May 2025, 10:19
Nikosar wrote:
23 May 2025, 09:37
Not sure what the difference is ....if you have a Red flag, you're effectively stopping. That's the whole point of a red flag. Although you don't have to change your tires under a red flag, you wouldn't gaining anything by not changing the tires. Even if there was a red flag in Monaco on the first lap, everyone would change their tires.
