Fits my expectations from the first time I read about this formula. But instead of "lost glory", I think it will be just really jarring (and maybe confusing) to watch cars slowing and turning while the engine is continues to howl.Holm86 wrote: ↑30 Jul 2025, 21:27https://www.auto-motor-und-sport.de/for ... in-hybrid/
So I guess we will also lose the glorious down shift sounds next year ...High revs even in the curves
So the battery is not only filled when the driver is on the brakes. Instead, gasoline is converted into electrical energy: "We had to come up with something. The engine switches to full load mode when braking and cornering to produce additional energy, which we feed directly into the battery. So the engine takes over the task of a generator in parts of a lap."
I think most people are more disappointed by the timbre, rather than the volume, even if they don't realize it. Though I don't think that will become more appealing either.Holm86 wrote: ↑30 Jul 2025, 21:27And as suspected, the volume won't really change because of the lower amount of fuel in these engines ...For those who had hoped that the volume would go up overall without the MGU-H in the exhaust system, Thomas has bad news: "The sound will only change a bit. This is not necessarily due to the expansion of the MGU-H, but rather to the changes to the turbo. The back pressure is reduced because the turbo does not have to drive the electric motor. This results in a little more sound. On the other hand, however, only three-quarters of the amount of fuel that goes into the engine is still available. On the test bench, we found a similar volume level as before."
I was thinking not all circumstances can be predicted. And it might happen that they run out of usable charge at the end of the lap in the start/finish straight. What else can they do? Using more energy is an instant DSQ, right?
There is no direct limit on deployment, so I don't think this can happen. The control unit will reduce the output before the battery runs out of charge.
Watch the video, they speak of the power reduction regulations from the 4.20 minute markkarana wrote: ↑31 Jul 2025, 16:11There is no direct limit on deployment, so I don't think this can happen. The control unit will reduce the output before the battery runs out of charge.
Yes, I wasn't referring to those limits, the way I wrote it is obviously false. I meant there is no direct limit on how much energy can be deployed per lap. Of course, due to the harvest limit of 8.5 MJ you can deploy at most 12.5 MJ per lap.Holm86 wrote: ↑31 Jul 2025, 17:54Watch the video, they speak of the power reduction regulations from the 4.20 minute mark
Yes if you have a fully charged battery entering the lap, you can spend 12.5MJ(9.5MJ at some tracks) during that lap, as the maximum state of charge is 4MJ, and maximum allowed harvest during the lap is is 8.5 MJ(5MJ at some tracks), so as you say, that limit is given by the regulations in that way.karana wrote: ↑31 Jul 2025, 18:51Yes, I wasn't referring to those limits, the way I wrote it is obviously false. I meant there is no direct limit on how much energy can be deployed per lap. Of course, due to the harvest limit of 8.5 MJ you can deploy at most 12.5 MJ per lap.
My understanding of what mzso was getting at is that cars might be reaching a certain limit on deployment before reaching the finish line and in order to avoid a DSQ having to reduce the output from 350 kW to 0 kW immediately. But the only limit is the SOC of the battery, which is predictable by the control unit.
But to me that just looks like they will be even slower at high speed tracks, as less braking zones means less allowed harvested MJ, and the ´turn-down ramp rate´bleeds off the power on the straights ...In response to drivers’ early misgivings, the FIA has adjusted the technical regulations to embrace a so-called ‘turn-down ramp rate’ which will taper the power delivery before the available charge runs out at tracks with high energy requirements. The sporting regulations also now enshrine a sliding scale of permitted energy harvesting depending on the venue, rather than the fixed amount of 8.5MJ per lap.
This latter tweak came in response to fears that at tracks with low demand for braking, the only way to harvest 8.5MJ over a lap would be to brake or lift-and-coast on the straights – a ridiculous spectacle as well as a potential safety issue. The cap will now be as low as 5MJ at some venues.
Yeah, we're not disagreeing, my post was in response to mzso, who argued that there might be scenarios where it's not possible to respect this ramp down of deployment without possibly deploying to much energy per lap (at least this was my understanding of mzso's post). I don't think such scenarios exist.Holm86 wrote: ↑31 Jul 2025, 20:07Yes if you have a fully charged battery entering the lap, you can spend 12.5MJ during that lap, as the maximum state of charge is 4MJ, and maximum allowed harvest during the lap is is 8.5 MJ, so as you say, that limit is given by the regulations in that way.karana wrote: ↑31 Jul 2025, 18:51Yes, I wasn't referring to those limits, the way I wrote it is obviously false. I meant there is no direct limit on how much energy can be deployed per lap. Of course, due to the harvest limit of 8.5 MJ you can deploy at most 12.5 MJ per lap.
If you look at the 6.10 minute mark of the video they explain the ramp down of deployment, so no it is not legal to go from full 350kw to 0kw in an instant, it has to happen gradually ...
Or else I'm completely misunderstanding what you are talking about.
Okay we totally agree then, such a situation should not be possible. It would be easy to program this down-rate into the ECU so you never go from 350kw to 0kw in an instant ...karana wrote: ↑31 Jul 2025, 20:27Yeah, we're not disagreeing, my post was in response to mzso, who argued that there might be scenarios where it's not possible to respect this ramp down of deployment without possibly deploying to much energy per lap (at least this was my understanding of mzso's post). I don't think such scenarios exist.Holm86 wrote: ↑31 Jul 2025, 20:07Yes if you have a fully charged battery entering the lap, you can spend 12.5MJ during that lap, as the maximum state of charge is 4MJ, and maximum allowed harvest during the lap is is 8.5 MJ, so as you say, that limit is given by the regulations in that way.karana wrote: ↑31 Jul 2025, 18:51
was removed in the previous version of the regulationsDesigns which allow specific points along the accelerator pedal travel range to be identified by the
driver or assist the driver to hold a position are not permitted.
Circumvent what? Isn't this to allow them to save (more) energy. Isn't it something they need to do rather than want to do? Or am I misunderstanding something? You're talkin about output power reduction, and not power for regen, right?
