saviour stivala
saviour stivala
43
Re: Mercedes Power Unit Hardware & Software
Also a visit to ‘piston ring development’ thread page will also interest some on the here subject.
OO7
OO7
171
GhostF1
GhostF1
115
Netflix Drive to Survive Season 2, the WIlliams episode shows the PU being installed and fired a fair few times.
OO7
OO7
171
MtthsMlw wrote:
05 Mar 2020, 22:11
Where on earth do these come from?
GhostF1 wrote:
06 Mar 2020, 02:09
Yep, they're from the Drive to Survive Netflix series. :)
Might have less drag with water to air cooler.
MarcJ
MarcJ
Titomic the rapid Titanium 3D manufacturing have announced they delivered a part to a formula one team last week using there kinetic fusion process. This could be related to the DAS dual axis steering, it could be anything really.
zibby43
zibby43
Somebody post what it says. I have boycotted Motorsport.com. :mrgreen:
zibby43
zibby43
PlatinumZealot wrote:
11 Mar 2020, 00:22
The problems in the first week, which led to Mercedes changing engines ahead of the final day of running, were caused by cooling problems with the MGU-H. By the second test, tweaks had been made to help overcome the issue and there was no repeat of that specific problem.
The trouble at the second test was caused by two bearing failures, and Mercedes has applied countermeasures for its spec-one engine that will be used from this weekend’s Australian Grand Prix.
Despite the testing problems, Mercedes has not had to roll back on the specification of engine it will use, and it is confident that it will not have to limit how aggressive it can be with engine modes in a bid to ensure reliability.
So Mguh bearing lubrication issues then.
Bill
Bill
It doesn't say anything about those pesky oil pressure issues
bosyber
bosyber
45
Wouldn't the MGU-H lubrication be with oil? In which case, that's where it was a problem, and apparently solved.
Bill wrote:
11 Mar 2020, 11:38
Bearing failures are often oil supply related, so fixing the bearing failure issue is likely to be oil related.
It is quite funny watching a RBR/Honda fan shouting how badly Mercedes are doing before anyone has run a race-spec car in anger.
dans79
267
Just_a_fan wrote:
11 Mar 2020, 14:07
Bill wrote:
11 Mar 2020, 11:38
Indeed, Hamilton's spectacular PU failure in Malaysia 2016, and subsequent loss of the championships was caused by a momentary loss of oil pressure that lead to a main bearing failure.
206 177 106 104 9 9 7
