2014 Engine yin yang
xpensive
xpensive
214
Re: 2014 Engine ying yang
WhiteBlue wrote:I love all this speculative chemical horse power chasing. Only that they have harvested all the low hanging fruits for ages. Here is nothing in the fuel regulations that would allow something they have not already done for a decade. Good luck.
Are you a chemical engineer now?Just your FIA-loudpeaker talking, the fuel-flow limit will open all sorts of can of worms.
The claimed +/-0.25% precision of the limiter is ridiculous to anyone with measuring xperience.
GitanesBlondes
26
The technical claim regarding the limiter is the sort thing that I imagine Max Mosley coming up with.
"I don't want to make friends with anybody. I don't give a sh*t for fame. I just want to win." -Nelson Piquet
munudeges
munudeges
-14
WhiteBlue wrote:Only that they have harvested all the low hanging fruits for ages. Here is nothing in the fuel regulations that would allow something they have not already done for a decade. Good luck.
The fuel regulations are completely different next year and is arguably the biggest differentiator, as it always has been. :roll: The game is very much on.
SectorOne
Not sure where these numbers came from but apparently the Renault engine produces 760bhp in combined output.
http://www.carscoops.com/2013/06/renaul ... er-v6.html
There´s no Renault details to be seen so i wonder where he got that info.
Great pictures though,
xpensive
xpensive
214
Those numbers are far more reasonable, 600 + 160 Hp.
SectorOne
So let´s assume that number is true, 760 combined.
And with the article that started this thread, 860 for Mercedes.
Impossible or maybe possible?
860 would be about what we have today in combined output, 760 merc engine plus 80 horses KERS.
xpensive
xpensive
214
A total of 860 is of course totally unrealistic, 700 Hp from 27.8 g/sec would mean an ICE-efficiency of some 40%
WhiteBlue
92
BTE of 40% is not only possible but very probable concidering that Merc are targeting that number and Renault are set to exceed it. I'm totally convinced that we will see BTE between 40 and 45% next year.
bhall
bhall
244
Since you're an engineer, WB, can you explain how we're going to see a ~30% increase in the thermal efficiency of the engines next year? I've read the manufacturer claims, but I can't seem to wrap my head around such a leap in performance. Any insight?
532
I would expect that any efficiency number of 40% includes power recovered from the MGUH.
tpe
tpe
-4
I am not an engineer, so, it might be a silly querstion:
Why on earth is this intercooler so large? Generally, the engine package seems not optimal at all. Is it just my idea, or not?
FW17
184
tpe wrote:I am not an engineer, so, it might be a silly querstion:
the image is using a current radiator in shape and size as a intercooler, it is not necessary that the same will be retained
WhiteBlue
92
wuzak wrote:I would expect that any efficiency number of 40% includes power recovered from the MGUH.
Indeed it would.
WhiteBlue
92
The intercooler is air to air which is very much less efficient compüared to air to water as the radiator works. Hence much more surface is needed.
WhiteBlue
92
bhallg2k wrote:Since you're an engineer, WB, can you explain how we're going to see a ~30% increase in the thermal efficiency of the engines next year? I've read the manufacturer claims, but I can't seem to wrap my head around such a leap in performance. Any insight?
Couple of things:
  • down sizing
  • down speeding
  • turbo charging
  • turbo compounding
  • direct injection
  • high compression
  • late injection after compression stroke
  • spray guided combustion
  • leaner AFR (stoichiometric)
If I keep thinking I will probably find some more points
