Aston Martin AMR26
FNTC
FNTC
Re: Aston Martin AMR26
Jambier wrote:
31 Jan 2026, 21:54
The weight I believe they can remove it, I’ m more worried about the engine.
They will have the weakest engine at start at least, don’t know how fast they can catch up
Pretty sure Audi might be worse. Also it depends how much the aero can compensate if the Honda engine lacks some power on Merc/RBPT/Ferrari
FNTC wrote:
31 Jan 2026, 20:55
At least they have five weeks until the first race to work on some weight reduction. Will be interesting to see if the front wing and/or nose changes at either Bahrain or Australia too.
The nose is not an accident or a "fake".
Beware of T-Rex
madridista
Jambier wrote:
31 Jan 2026, 21:54
based on ?
hollus
Winning and losing in the team thread. Thanks. Deletions are happening below this post, even if you probably can't see if for obvious reasons.
Car thread --> On topic, please.
¡Puxa Sporting!
mzso
mzso
76
chlebekf1 wrote:
31 Jan 2026, 10:47
It's a pity that so much hot air will go to the rear wing/suspension
Under the rear wing.
Chuckjr wrote:
31 Jan 2026, 10:52
Second, is the huge side exit/opening sending hot air from the side pods to improve air expansion post the side pod pinch point in front of the rear wheel? Their exits are proximal to each other, and why I ask. I know the air coming out of that opening is not clean, but is there enough heat coming out of that opening to improve expansion at the rear wing?
Suspension element warmer. :)
Giogio
Giogio
I was watching the video of KYLE.ENGINEERS. When he talked about how flows are directed on floor board, I understood that, but when he started talking about creating certain pressurization points, I didn't understand what he meant there. Can someone explain this to me or cite articles where I can find out? Thank you very much in advance
Lastminutepanic
Lastminutepanic
Giogio wrote:
01 Feb 2026, 14:32
Think of high pressure areas in aerodynamic models as invisible bodywork. The easiest way i know of to explain it, is like the designers are trying to keep high/low pressure areas in very specific places, where they are useful. For example, there is a high pressure area in the area directly infront, and above the front wing, and a corresponding low pressure area directly behind the horizontal front wing elements, and how you shape the wing, ex: tapering wing elements from inside-outside, or outside-inside, will give the two channels of flow on either side of the nose a very different form. If the front wing has more aggressive elements near the center, it creates a large low pressure zone near the nose, creating an inwashing effect for the airflow, and a front wing with more aggressive elements towards the end-plates, will create a low pressure area further outboard, with an outwash effect for the air over the nose of the car. The same principle is used for every part of the surface of a car. You cannot avoid high pressure areas, or you would have a car with 0 drag. So the game being played is to place the high pressure areas so they create corresponding low pressure areas in the most advantageous places (under the floor, under the wing elements, infront of surfaces perpendicular to direction of travel). There is also the engineering of laminar and non-laminar flow (non-laminar is usually called "turbulent"), designers typically only want smooth laminar flow touching the car. Turbulent flow increases drag, decreases the cooling ability of the air, and lowers the air pressure, reducing wing performance. Usually non-laminar flow is dumped outboard, or up, if its created early. Or through the empty, open area of the rear wing if created at the rear of the bodywork. There are always fun little exceptions to every explanation though, like the reason why F1 cars have such incredible "ground effect" without using the skirts seen in the 70s/early 80s, is the harnessing of small turbulent "eddies" (like horizontal corkscrews intentionally disrupted airflow) directed along the edge of the chassis. That is a major function of the small vanes and winglets on the front outboard section of the floors. Same goes for the large channels running from the sidepod intakes, down towards the rear floor. They want to increase air pressure directly on the rear floor, and onto the top of the rear wing, and leave a huge area of turbulent, low pressure air through the middle of the rear wing. This will help scavenge airflow from the diffuser, lowering airpressure even further under the car, and makes the air as messy as possible for anyone following them.
vorticism
vorticism
449
Source: F1 official media
FNTC
FNTC
Last image there, open rear wing, fixed front wing. No active front wing, as suspected.
vorticism
vorticism
449
The lack of bodywork beneath the sidepods is remarkable. No other team has this. The width at the base of the sidepod is effectively the width of the fuel-cell/safety-cell/monocoque (note the vertical lines that descend directly from the halo mounts). Straight shot from the forward floor to the gap between the rear tyre and the diffuser. That gap can be seen from the front of the car. Straight groundline. I’ve highlighted it here.
A feat of packaging? Usually components are housed beneath the radiator ducting.
Jambier
madridista wrote:
31 Jan 2026, 22:53
Jambier wrote:
31 Jan 2026, 21:54
based on ?
Honda declaration that they were happy with electrical power but not with the ICE for now.
So let’s see.
Rikrikrik
Rikrikrik
Jambier wrote:
01 Feb 2026, 22:23
madridista wrote:
31 Jan 2026, 22:53
Jambier wrote:
31 Jan 2026, 21:54
based on ?
So let’s see.
We dont know what they expect, its not means they are worst or whatever.
BassVirolla
Probably one of the tightest packed F1 of ever, even more the said zeropod of Mercedes, which rear looked as slim as a walrus seen from the back.
GhostF1
GhostF1
112
vorticism wrote:
01 Feb 2026, 20:51
https://i.postimg.cc/Hsc5DZ0M/amr26glinevorticism-1.jpg
What's wild is, its even more tightly packed than you've outlined (excuse the rough outline below). It's a remarkable achievement from what they've shown so far.
Not very surprising from a car made by Newey. These simple and clever chassis design ideas were one of the little secret ingredients of the last successful RBs.
He for sure started by focussing hard on the internal layout and packaging of the car. Cowell hinted on that in one of the interviews. (obviously the 2026 regulations are different from the 2022 era, so let's see what smart ideas he and his team used...)
