McLaren have chosen some interesting design routes on their new competitor. In addition to our own technical analysis, McLaren's Tim Goss and Paddy Lowe explain why some decisions have been made in light of the regulation changes.
Blackout wrote:I don't think there is a 'secret'... the 2010 steering wheel is shaped to be more comfortably held that way...
Maybe i am crazy, but in the youtube film you see that up the hill (00:38) he puts his hand almost on his leg. And then at (00:44) he hurries to get his hand back to the Steering wheel to shift back.
I don't know, but that doesn't look very comfortable to me
What does IDK means?? (someone) i dont know (other dude) OMG no one knows
diffuser stalling have bn discussed before, and stalling it will simply add drag, you siply block alot of xit space due to the stalling, air willheap up under the floor and will cause an unstabl car.
Perhaps operation with the knee is not easy for the drivers and it was only ever implemented that way to try and hide it for as long as possible. Now everybody knows how it works they moved the 'switch' to a more optimal position for the drivers.
Almost every track is driven clockwise. Their knee activated f-duct is on the left side of the cockpit. Perhaps the gforce of fast right corners makes it difficult to hold their knee away form the left wall of the cockpit???? It would not be good if their knee blocked the duct-hole in a fast right loosing alot of downforce on the rear.
raymondu999 wrote:I don't think you'd position your knee anywhere near the vent in a corner though...
Its on the straight where it is used! And as for corners, it would be equally dangerous to move your hand to cover the opening, whilst trying to steer around a corner.
You are misunderstanding me. I never said it was used in corners. Im saying the exact opposite. Im saying the gforces in at corner could force their knees toward the switch. Wich would be dangerous if their knee activated the switch in a corner.
That's why it would make more sense to place above the knee. Then the driver only has to retract his foot from the brake, and the knee goes up by itself.
Anyways, Mclaren clearly has it in the side of the cockpit now, one can even see the hole in the in in-car video of the pole of Canada: http://www.youtube.com/watch?v=AK6S4nAwmGM
hollus wrote:That's why it would make more sense to place above the knee. Then the driver only has to retract his foot from the brake, and the knee goes up by itself.
I cant see any hole? If there was a hole then why does LH not move his hand to cover it on the main straight?
You can only see the hole when the light is right (I hope it is the hole I am seeing, the resolution is a bit low).
It is clearer to see at the end of second 36, when his hand criefly moves away, and through the following corner. It is visible again at the 1:07 time mark.
In the main stright he puts his hand on it at the 1:25 mark, and he flicks the fingers out of it after the finish line (the little white thing in the back if his gloves, but at finger level, not in the back of the palm). But now that I reviewed the video in more detail, it looks like he is not covering the hole at every oportunity he could.
BTW, why isn't this the video from Canada in the formula1.com site?
