Sergej
yeah let's not rush judgements, still plenty to see: sprint race, main quali with hopefully a better setup, main race
let's see tomorrow
venkyhere
I dont care for the sprint, the fact that Max did two Q runs on a single set of C5 tyres in 45 degree track temp, shows that the whatever 'updates' have been done, have massively improved tyre life. I hope they don't bother about hte sprint and not fall into the trap of taking out a bit of RW to improve the straights. This car can be on pole in the real Q on Saturday, and then enjoy clean air to run to victory in the race. It all depends on what 'changes' between now and Q session. The actual thing that needs 'work' is the T17 final corner. Mercedes might win the sprint but have to raise the car for the race and will be behind McL and RBR on Sunday.
Is the straight-line loss simply because they're running more DF?
Juzh
161
telemetry vs Antonelli. Low speed T11-T15 and especially last corner T17 is atrocious
- telemetry curtesy of emag. Nice site you got there :) also very nice how fast telemetry is available after a session.
Cs98
Cs98
02 May 2025, 23:34
Albano highlights our issues on the straight
Every other car has shed loads of drag by running lower wing levels than previous years. It's only RB that has been caught completely napping on their wing options. U-wing + flex = loads of time.
Juzh wrote:
02 May 2025, 23:42
https://i.imgur.com/asGPVIH.png
Particular issues in T11, T12 may be due to the curbs on the apexes there. T17 really was poor but I think that is probably a corner where you give up laptime if you try to build a setup that doesn't hurt the rears too much (cope)
venkyhere
02 May 2025, 23:42
i think its because the RW doesn't 'bend down' enough like the others in the straights. THis is going to reamain the same after barcelona even (as the 'delayed' TD doesn't address this) , and will be a characteristic till end of 2025. Redbull can say bye bye to Spa and Monza , unless they do something about this.
venkyhere wrote:
02 May 2025, 23:56
02 May 2025, 23:42
They can make improvements in that area, but Red Bull have a larger rear wing this weekend. It's unmistakable.
venkyhere wrote:
02 May 2025, 23:41
Replaying Max's T17 on the final lap, there's nothing "wrong". It may have just been too conservative. Drivers have to judge how much grip they think they will have before they choose the braking point. There is no lockup, no understeer and no wheel spin. Perhaps he is not used to having tires that still work at the end of the lap :lol:
Max never complained about tire overheating on the radio like he did in previous weekends. I think something is different. It's a sprint weekend. They need time to fully maximize the car with what the update package allows.
Cs98
Cs98
02 May 2025, 23:58
venkyhere wrote:
02 May 2025, 23:56
02 May 2025, 23:42
Problem is they've never had a smaller rear wing than this one and its equivalent predecessors, they just used the cheapskate cut-out BS. If they don't have a proper low DF wing for Spa, Monza, Baku, Vegas, you can kiss bye bye to any hopes of a championship because they are not competing at those circuits with what they have now.
Emag
Emag
Juzh wrote:
02 May 2025, 23:42
Thank you! Telemetry is available live during sessions as well, just a bit lower quality and takes quite a bit longer to process. Now data has been parsed completely, so that T17 turned out to be an artifact of the low sample rate. Kimi still had a mighty last corner though, just not as amazing as it looked before.
Developer of F1InsightsHub
Max's T17 was very tidy visually. So this makes more sense.
So it's consistent time loss on every straight
CjC
CjC
03 May 2025, 00:17
I’m with you, it would suggest Red Bull run more wing these days than the others. Helps them in high speed, helps with tyre degradation (Jeddah) but gives them lower top speeds and Max again said he had understeer in the low speed after sprint quali.
Just a fan's point of view
Paa
03 May 2025, 00:17
But this is calculated, right? We have already seen yesterday that RB have the biggest rearwing.
Maybe this is what Horner was referring to after sprintqualy.
