Williams FW42
netoperek
netoperek
Re: Williams FW42
Holm86 wrote:
25 Jul 2019, 11:00
Blaze1 wrote:
25 Jul 2019, 10:28
Awesome picture of that impressive radiator/intercooler design. I think I posted a question here a few years ago asking why the radiator's aren't curved to help with packaging and I was told (If I remember correctly) that it couldn't be done, due to manufacturing and or design difficulties.
Im wondering when they'll start 3d printing the radiators, to make even more extreme shapes :D
But maybe you can't really 3d print aluminium ....
You can print aluminum but the results aren't that good. There are other lightweight materials that could be used though. 3D printed radiators would make a ton of sense due to natural surface roughness of 3d printed models. It could also potentially be even cheaper than traditional manufacturing.
Holm86
261
Re: Williams FW42
netoperek wrote:
25 Jul 2019, 11:26
Holm86 wrote:
25 Jul 2019, 11:00
Blaze1 wrote:
25 Jul 2019, 10:28
I wasnt thinking about it having to be light weight, because I know you can print titanium pretty well.
But you need a material with good heat transfer, thats why they use aluminium
ScrewCaptain27
577
Re: Williams FW42
New bargeboards and floor:
- Serj Tankian
Tattoo-
Re: Williams FW42
from AMuS
new:
old:
new:
old:
"There are only three sports: bull fighting, car racing and mountain climbing. The rest are mere games!" - Ernest Hemingway
Re: Williams FW42
I think after 2 years of harping on about it, the chicken wing device on the bargeboard seems to be the way to go. Every team is headed in that direction or pushing it further.
Ashwinv16
Re: Williams FW42
godlameroso wrote:
25 Jul 2019, 18:35
It simply act as a guide to the disrupted flow coming from the front tyre wake, and the vortex from the front wing tips (Which itself is guided by the turning vanes and the cape under the nosecone). This part helps to smooth the flow out thus the sidepod turning vane can better guide them around the side pods for flow attachments purposes(Reducing drag and aero instability). At the same time they guide the flow onto the floor and to the new longitudinal slot openings that basically allows for the air to flow under the outer edge of the floor creating a virtual curtain that seals the gap between the leading edges of the floor and the ground so that the air flowing under the floor does not escape through the side thus helping improve the efficiency of the diffuser as well.
Thus of course all teams need to explore this device as it has huge benefits considering the only problem being rigidity, drag and weight.
Halo not as bad as we thought
Re: Williams FW42
Ashwinv16 wrote:
25 Jul 2019, 19:05
godlameroso wrote:
25 Jul 2019, 18:35
It also has the added benefit of being very close to the ground, and a high rake concept will move this device further away from the ground. Thus finding the right pitch for the device has a huge influence on the rest of the car aero. Seeing as how that's partially determined by the tub, I could see why chassis modifications would be needed to get the most out of it.
I think you make an excellent point regarding not only the geometry but the physical properties of the "chicken wing". As I stated it's very close to the ground and controlled deformation could change it's aero properties at different speeds. At the same time one has to be careful to not make them too flimsy or they could stall or worse break off.
Cuky
65
Re: Williams FW42
Is it only me or the engine cover has different shape to it as well?
Tattoo-
Re: Williams FW42
Cuky wrote:
26 Jul 2019, 09:58
Jup, engine cover (exit) is different and is now more shrink-wrapped. =D>
Re: Williams FW42
ScrewCaptain27 wrote:
25 Jul 2019, 16:23
Looks like Williams have borrowed Mercedes's body moulds. :lol: =D>
Cuky
65
Re: Williams FW42
Tattoo- wrote:
26 Jul 2019, 10:26
Cuky wrote:
26 Jul 2019, 09:58
https://www.racefans.net/wp-content/upl ... 718-10.jpg
Not only that but the part where it says "Rexona" seems to be more sculpted and tightly wrapped too
LuisFeF1
125
Re: Williams FW42
New rear wing endplate:
LuisFeF1
125
Re: Williams FW42
New diffuser:
Re: Williams FW42
Via AMuS
ScrewCaptain27
577
Re: Williams FW42
AMuS
- Serj Tankian
