Balance was a significant issue for the SF 23 as well last year. Leclerc described the car as inconsistent both corner to corner but also "intra" corner, with the balance changing to oversteer and understeer "randomly".
In fact, it's just the scapegoat so as not to admit having worked badly. End of speechOnEcRiTiCaL wrote: ↑24 May 2024, 14:09I think in Monaco Mercedes proved, that nothing wrong with that rear suspension...
Better balance, no word about DF. I fear the wing simply doesn’t work as it should.
I don't they didn't use it cause it was a problem. I think this wing is just higher DF. No High Speed sections to take advantage of the other wing's abilities.
They've said it wasn't a problem for a while now. I'm not even sure they ever said it was a problem.xReVo wrote: ↑24 May 2024, 15:20In fact, it's just the scapegoat so as not to admit having worked badly. End of speechOnEcRiTiCaL wrote: ↑24 May 2024, 14:09I think in Monaco Mercedes proved, that nothing wrong with that rear suspension...
