hardingfv32 wrote:Is this such a big deal for performance in the corners? The cars are off throttle during braking and I know there is some breaking into the turns, but once off the brakes they are back on the throttle. Maybe not 100%, but certainly out of the off throttle mapping regime.
Brian
@ Brian, I also think the ban (as stated in the press) would not be a big deal. It would reduce grip during braking. Braking is important to overtaking, but it's a relatively small contributor to overall laptime performance. The RB advantage is biggest at places like Spain where the medium-speed corners go on forever.
Earlier this season it was revealed that several F1 teams use detents toward the end of the throttle pedal travel to activate KERS output. Clever.
A detent could be added at the beginning of the throttle pedal travel to activate the blown diffuser while adding, say, 2% torque. This would allow the driver to consistently blow the diffuser during braking while adding a bit of torque to comply with the new FIA regulations. Pushing through the detent would put the pedal into the "normal" zone where, apparently, blowing will still be unregulated.
Actually this is rather obvious so I assume the FIA is also attempting to ban this workaround. I think enforcing the direct intent of the rules (no blown diffusers) plus banning all the conceivable workarounds will lead to complex and vauge rules.
So far these new rules have been kept secret from the public, but don't get me started on that. I'll refrain from pushing through my personal complaint-limiting detent
