etsmc wrote: ↑28 Jul 2017, 06:29
Have been thinking about the cooling flow and how the front of the car is affecting it.
Would it be an idea to have a finer mesh on the suspension components? I have thought about running 2 tests side by side to see if the effects are worth it of not, is it as simple as placing the suspension geometry in the High_Res folder along with the other parts?
Has anyone else thought about or tried this?
Please give it a try. You are right, it is only a matter of placing these parts into the high res folder.
I have had my legality checks back a couple of things to fix up for the next race, the one thing I was concerned about passed. See if you can spot it when Andre releases the renders.
Avoiding Chris's eagle's eyes is something you should be proud of. I always see his emails for you guys. I have no idea how he always spots everything so fast.
Another thing that might be handy for the post processing tool would be to output an image of the monitoring surface.
Good, idea. I think I have it implemented in the full version (once someone asked for it). I will see if I can release it for the next version. It would esp. help those guys who tessellate the surface incorrectly. And the more advanced users will see how uniform the flow passes the HX.
