Red Bull RB15
Re: Red Bull RB15
roon wrote:
28 Feb 2019, 22:06
Shows well how the bar/cover/hoop over the s-duct opening should be acting as a venturi.
Exactly. This venturi then sucks air out of the s-duct helping to pull air from under the nose and thus help the front wing (and the turning vanes below the chassis, presumably). A venturi pump. Similar to the aspirators used to inflate aircraft escape slides.
Sieper
73
Re: Red Bull RB15
Whilst at the same time attaching the flow to the top of the bodywork, then down the side and via that slope that only RBR has (and McLaren now also a bit) curls back under the tail and the exits on top of the diffusor, Hopefully improving below Floor suction as well.
Flying JPS Lotus
37
Re: Red Bull RB15
They're running the struts again today. Only it's black this time.
https://twitter.com/AlbertFabrega/statu ... 4347238401
"Looks like meat's back on the menu boys!"
#AeroUruk-Hai
Re: Red Bull RB15
Via AMuS
paddyf1
paddyf1
Re: Red Bull RB15
The struts at the back of the red bull, they are to strengthen the floor, during testing i have seen the corners of the diffuser vibrate.
nacho
nacho
Re: Red Bull RB15
Struts have threads for adjustement, though the upper nuts are marked with loctite.
paddyf1
paddyf1
Re: Red Bull RB15
nacho wrote:
01 Mar 2019, 13:24
"Red Bull continues with its suspenders in the background to maintain stiffness and evaluate different heights". "Playing with aerodynamic structural elasticity as it is called".
Tzk
Tzk
36
Re: Red Bull RB15
Maybe they reverted to an older floor (just like the bardgeboards) and this old floor simply flexes too much?
Sieper
73
Re: Red Bull RB15
I think they produced one reinforced floor over the weekend (by adding extra patching to an existing floor, ad hoc) and that that floor has been crashed into oblivion by Pierre yesterday so now we are back at the old floor (with reinforcing struts to stop the buffeting / vibrating like spotted by PaddyF1.
In Australia a better floor will be ready.
ME4ME
82
Re: Red Bull RB15
Also note the reflective squares on the diffuser vanes. There might be some kind of camera / optical sensor installed beneith the rear crash structure.
Newey actually confirmed at the end of last year that they had found a diffuser issue mid-2018, re-designed it and been much happier ever since. No doubt they would like to start this season with an aero optimal and also structurally-verified diffuser concept. This will make sure that they know what's going on with the rear end of the car, so that all the data from the first view races is valid and usable as a base for development of future upgrades.
roon
roon
412
Re: Red Bull RB15
A piece of CF branches off the RW support and goes into engine bay. That should be a shroud for the DRS hydraulics. Last year this was integrated into the upper spine of the engine cover. This year the engine cover is higher.
RB14:
Re: Red Bull RB15
Sieper wrote:
01 Mar 2019, 15:39
that, or, as said above with elasticity, to change the degree in which the floor angles just minimally. just so that it doesn't break, but mimics/imitates a more curved (or less curved) angle.
roon
roon
412
Re: Red Bull RB15
RB don't use diagonal structural links between the gearbox and the diffuser. Merc, Ferrari and others do. Apparently this imposes some challenges.
Sieper
73
Re: Red Bull RB15
Wow, Roon, I never spotted that, or took any notice of it is perhaps better said.
It even looks like those rods could be put under extra or less tension at Ferrari especially with it disappearing into the housing and all those couplings. Ofcourse moveable aero is out of the question. Merc also seems to have moveable couplings. In Any case, Yes they all have struts. And they all have double rearwingbsupports and RBR has neither in the chase to loose drag.
Zynerji
112
Re: Red Bull RB15
Sieper wrote:
01 Mar 2019, 23:56
I must say, the Ferrari setup definitely looks as if it could easily hide a mechanism to hydraulically twist the floor/ diffuser to enhance mid corner stability...
Not saying they are, but the hidden end of the strut definitely makes the imagination go wild. It could also be something as simple as anchoring the hidden end to the right part of the A-arm flexture or pushrod bell crank to get similar results...
