Ferrari SF-26
brakeboosted
Re: Ferrari SF-26
14 Feb 2026, 17:28
Did anyone happen to see the picture on one of the blogs or social media that showed the inside of the Ferrari front wheel? I remember seeing it and it was very similar to this on the inside.
https://i.postimg.cc/GpbM6SJX/image.png
I thought it was interesting, but can't find the picture anymore.
via scarbstech on X
Re: Ferrari SF-26
14 Feb 2026, 19:23
PlatinumZealot wrote:
14 Feb 2026, 18:02
New demands on the front and rear brakes with the additional regeneration. Perhaps the front brakes have a mode to reduce clamping force so that most of kinetic energy is taken by the rear. It means in this mode longer braking distance and that it will be important to keep the front warm.
Are you describing the brake bias?
Yes but the range might be preset within a certain charging mode.
Re: Ferrari SF-26
brakeboosted wrote:
14 Feb 2026, 19:46
14 Feb 2026, 17:28
https://i.postimg.cc/dV7vL67c/HBCHWKDbs-AA48nd.jpg
via scarbstech on X
That's the one!
Beware of T-Rex
DinkLv
DinkLv
64
Re: Ferrari SF-26
A shot on top of the diffuser during the run by Michael Potts:
Emag
Emag
137
Re: Ferrari SF-26
Owen.C93 wrote:
13 Feb 2026, 02:28
Interesting little flicks on the corner of the diffuser. It’s been pretty standard to indent the corners to help flow attachment, but they’ve used the loss of volume to add a little turning vane.
https://www.pmw-magazine.com/wp-content ... F1-3-5.jpg
https://www.pmw-magazine.com/wp-content ... F1-4-4.jpg
This is the most interesting diffuser of the grid at the moment. The middle wings are not unique to Ferrari, but they're the only ones that have it fully connected with the top diffuser edge like this.
I think what's happening at the edges is quite a bit more interesting in my opinion. I think Ferrari are the only ones who use the diffuser winglets in this manner where it looks like they have an "extended" diffuser sidewall at the exit.
Developer of F1InsightsHub
Sansovino
Sansovino
Re: Ferrari SF-26
Emag wrote:
15 Feb 2026, 14:30
Owen.C93 wrote:
13 Feb 2026, 02:28
To me it looks like the Haas is doing the same "extended" diffuser trick too.
https://www.pmw-magazine.com/wp-content ... -F1-14.jpg
RagingBullx
RagingBullx
Re: Ferrari SF-26
Anisotropic carbon fibre, another name for weave layup or is there more?
sucof
37
Re: Ferrari SF-26
Interesting video.
Looking at their sliding out of the corners, I feel they are not under or over steered, but simply they have too much torque when accelerating out of the corners...?
Hence the rear wheels loose grip slightly, and starts to go everywhere, that is what the drivers try to correct.
To me it seems all these are happening after the most of the direction change of the cornering has been done.
So they might have a software issue to fix to have a power deployment that matches the grip better...
SiLo
144
Re: Ferrari SF-26
sucof wrote:
16 Feb 2026, 15:57
Interesting video.
I imagine the deployment will be one of the biggest thing that changes over testing, so they will find they can deploy less during acceleration phases and still be fast because its easier for the drivers to manage.
Felipe Baby!
RagingBullx
RagingBullx
Re: Ferrari SF-26
I was most interested in the videos rumour the suspension components are "anisotropic" and so needed tweaking to improve grip and traction, which might explain the drive and braking issues LH had?
f1316
88
Re: Ferrari SF-26
RagingBullx wrote:
16 Feb 2026, 15:05
If this is true (and I have zero expertise to opine on the likelihood), presumably it’s something we’ll be able to observe? Ie the suspension would be visually different under different loads.
What I will say, which could fit this story, is that it was previously said that Ferrari were waiting on the ok from the FIA before bringing some of their updates. Now you could guess that the “diffuser extension” could be one such thing - ie will they approve Ferrari’s interpretation to basically get a bigger diffuser - but this one could also fit in that category. Again, if true, you would imagine rival teams would call this a “moveable aerodynamic device” and push for some kind of rigidity test. That certainly would fit with Fred seeming to walk back his objection to the compression ratio thing a little bit (since it’s a similar conceptual thing around measurement vs intention).
cplchanb
cplchanb
Re: Ferrari SF-26
14 Feb 2026, 23:10
brakeboosted wrote:
14 Feb 2026, 19:46
14 Feb 2026, 17:28
via scarbstech on X
That's the one!
Interesting.
I thought it would be a solid wheels like the RB teams.
matteosc
matteosc
32
Re: Ferrari SF-26
f1316 wrote:
16 Feb 2026, 18:48
RagingBullx wrote:
16 Feb 2026, 15:05
Based on the description it is a matter of layup direction, which is pretty common in carbon fiber components. Carbon fiber is anisotropic by nature and there is a lot of work done to "tune" its flexibility in different directions.
Its application to suspension arms is however potentially innovative, it all depends on the extent in which this is exploited.
Brahmal
Brahmal
74
Re: Ferrari SF-26
Brahmal
Brahmal
74
Re: Ferrari SF-26
