2016 European Grand Prix - Baku City Circuit, Fri 17 – Sun 19 Jun
SR71
Re: 2016 European Grand Prix - Baku City Circuit, Fri 17 – Sun 19 Jun
FoxHound wrote:@Juzh
From the 6 minutes of Red Bull and Ferrari footage I've seen, they have massive issues and all in relation to traction in and out of corners, when accelerating, turning or braking.
I'm guessing the track is "green", but both teams will be hoping the track rubbers in.
Red Bull must be doing this on purpose. Probably ordered by Red Bull Marketing (not a real thing) in order to keep up Marko's comments.
FoxHound
55
giantfan10 wrote:Actually the main reason Ferrari is off the pace is because they are both running pre montreal engine
Explain then, why Ferrari are having traction issues?
Is it because the pre montreal engine was so vastly different, that it changed the geometry of the suspension to the point of messing up the entire car? A car that was, with pre montreal engine, about 0.5 off the Mercedes at other tracks?
It's about tyres and traction. Not engines. Tyres and traction, tyres and traction I'll reiterate.
The track will at some stage rubber in, benefiting teams that are suffering with traction. But you simply cant palm this off as use of a practice engine, which likely Mercedes are doing exactly the same anyway.
JET set
SR71
So no percentage of the time ferrari are off pace can be accredited to the old spec PU?
You're saying it's likely Mercedes practice PU is an ouddated spec with the same performance difference that ferrari have between their latest spec and old?
Chuckjr
Fulcrum wrote:
j2004p wrote:
Fulcrum wrote:Sorry, that's not an argument that holds much water with me. That's actually part of my point. Placing kerbs on this track where they have effectively neuters it.
Why do the drivers need to have 'something' to 'negotiate' with?
You've stated it yourself. Without kerbs the balancing act is negotiating the wall, which seems a much better application of skill than 'negotiating' an arbitrary point like a kerb.
As such, removing the kerbs would place a much higher emphasis on the driver than the car.
OK, maybe I'm missing something and if I am I apologise, but what would you prefer instead of a kerb?
A wall or a white line with identical flat tarmac to the main track on the inside of the white line?
In essence, yes, or very nearly. There are plenty of turns on this very track where the kerb literally hugs the wall. Examples being, turns 1, 3, 5, 9, 10, 11, 12, 13, 14.
Turns 2, 4, 6, 7, 8, 15, 16 all create artificial apexes and I don't see the point of this when the track is physically bound by concrete blocks. The safety argument, slowing cars down with strategic kerb placement, doesn't correlate because the kerbs are tight on entry to T1, T12, T13, T14, all with high approach speeds or high apex speeds.
I don't see how the kerbs here can even be motivated as safety features at all. They're raised, destabilise the car, and are likely to cause more accidents than they 'prevent' from an errant driver getting too close to the wall. What's more, they're extremely dangerous in the wet - not that important here as it doesn't rain much.
The approach to turn 15 is actually made more dangerous by the completely idiotic kerb placement on the outside of the track in the approach.
To summarise, my general argument is that the placement of the kerbs creates for a far worse layout than could be experienced were they placed consistently close to the walls throughout, the best examples being T15 and T16. Both of these corners have been 'sanitised' in a manner that detracts from the circuits potential.
I agree with your argument 100%.
IMO they have done it to impotize the track and remove a driver error from being a retirement. The idea is to have as many cars on track running at all times. This is a show and business before it is a competition. The idea of risk and terminal mistakes are no longer on the table for discussion.
They also did it to slow the corners down and force -possibly- more passing opportunities. As Button said its a lot like Canada, 90 degree turns followed by long straights.
Sterilizing the tracks and ensuring cars are always running as much as possible is the whole idea now. Tradition, history, driver skill, these are all secondary or non concerns.
Funny how quickly drivers forget how bad domination is to the sport. Oh the irony!!
http://metro.co.uk/2013/10/07/lewis-ham ... t-4136945/
Watching F1 since 1986.
LookBackTime
LookBackTime
472
From AMUS:
They had loaded their cars with Barcelona-wings. Only Mercedes, Williams and McLaren started the adventure on the new route with wings at the spa format. The result proved them right. The 3 cars occupied in the first session and the first places.
driver Average longest long run Round Tyre type
1. Hamilton 1.48,767 7 supersoft
2. Rosberg 1.49,502 10 supersoft
3. Perez 1.50,044 9 supersoft
4. Bottas 1.50,107 18 supersoft
5. Hülkenberg 1.50,232 10 supersoft
6. Kvyat 1.50,281 16 supersoft
7. Raikkonen 1.50,450 10 supersoft
https://translate.google.com/translate? ... edit-text=
SamH123
SamH123
Ferrari had good pace in s3 so the engine argument falls flat
Haryanto almost matched them in s2
giantfan10
giantfan10
27
An old mercedes engine functioning as it was intended to function is more than likely a much better engine than the Ferrari engine with a bum turbo and MGU-H that couldnt even sustain max power along the Bahrain start finish straight which pales in comparison to its counterpart in Baku.
Please point out where i said that Ferrari using an old spec engine was the ONLY issue.MAIN issue versus ONLY issue. : )
Attack on another poster has been removed.
ME4ME
82
LookBackTime wrote:From AMUS:
Yet Amus reported yesterday that Red Bull would do a back to back comparison between the Canada and Barcelona wings.
I think the main reason for the competitive order shake-up are the tyres. Pirelli have been very conservative not only with compounds, but also with the prescribed starting pressure of 22 psi. Accourding to Motorsport.com Pirelli is now evaluating data from FP 1&2, and might decrease pressures if possible.
dans79
267
ME4ME wrote: I think the main reason for the competitive order shake-up are the tyres. Pirelli have been very conservative not only with compounds, but also with the prescribed starting pressure of 22 psi. Accourding to Motorsport.com Pirelli is now evaluating data from FP 1&2, and might decrease pressures if possible.
Also said they might raise it as well.
202 105 104 9 9 7
holeindalip
holeindalip
Ferrari had a rear suspension geometry update in Monaco maybe it won't let them get heat into the tires here??
iotar__
SamH123 wrote:Ferrari had good pace in s3 so the engine argument falls flat
Even without sector times: old turbo saving engine would not explain such difference, Traction/tyres specifically - why would they have bigger problems than TR/FI?
Those wing/DF aspects posted earlier seem plausible. Some other rather vague ecplanation, P. Charles (TR) (pitpass):
"It is clear that some teams and drivers have hit a sweet spot while some others are not quite in their usual ranking position. This means there are some factors that are specific to this circuit, which we need to understand and react to tonight. It will also be tricky to try and second-guess the track changes that will happen as the new tarmac settles and the temperatures increase through the weekend."
ChrisDanger
ChrisDanger
26
SectorOne wrote:
ChrisDanger wrote:
SectorOne wrote:Medical car doing a lap around the track. I have my doubts on 18-19 being flat.
http://www.formula1.com/content/fom-web ... _Baku.html
Ricciardo said it's flat (during commentary over video of game footage), and Alonso said a lift will probably be required (I couldn't tell how sure he was) (during first question of driver's press conference).
It´s flat in the game he was playing, F1 franchise games are not known for their accuracy.
I wasn't able to catch any of today's coverage, but Hamilton was clearly flat in the onboard posted here. What about the guys lower down the order?
For the record, I assumed Ricciardo was speculating from simulator experience, and was just commentating over game footage. I hope I don't come across as that stupid.
nacho
nacho
The track looks a bit fast for no runoffs. Those 290-300 km/h corners look a bit scary tbh..
giantfan10
giantfan10
27
Thats not an engine arguement thats an engine fact and one of 2 facts that we have at this point when trying to explain Ferrari being that slow in practice.
Second fact is Kimi and Vettel both saying that they were having issues getting the tires up to temp over one lap but that it was fine after that. They both said they have work to do overnight.
Vettel said he wasnt worried.
As usual panic ensues lol
Come tomorrow when its actually a real competition and not practice we will see who is where.
ChrisDanger
ChrisDanger
26
