2019 Renault F1 Team
kptaylor
kptaylor
Re: 2019 Renault F1 Team
I took "driveability" to mean the mapping of the engine and its controls. How/when you add electric power, how/when you use regen to recharge, how/when you split between recharge and power to the wheels, how you limit torque from the electric power, how/when you use the electric power to spin the turbo, spin the MGU units, etc. You can have over 1000 BHP but if you can't put it down consistently or can't put it down in the most efficient manner so your overall pace is best (subject to fuel constraints and the desire to be efficient), then its "driveability" is not good.
ispano6
164
There is a correlation for Honda, his name is Yasuaki Asaki. And people from passenger powertrain departments are put into Formula projects all the time. Probably why they don't always have racy engines. But sometimes, it is to bring reliability to overly fragile racy engines. Not sure what Renault does with it's personnel but I imagine it's similar. You should not assume no correlation because that's simply not correct.
https://patents.justia.com/inventor/yasuaki-asaki
ispano6 wrote:
07 Apr 2019, 19:19
Nope not what I said.
diffuser wrote:
07 Apr 2019, 19:45
ispano6 wrote:
07 Apr 2019, 19:19
No Correlation as in (not saying this is true, just an example): Just because the Honda PU in the NSX has more drive-ability than Mercedes EQ's PU doesn't mean that the Honda PU has more drive-ablility that the Merc F1 PU.
Different goals/expectations and different measurements. One is tested weekly by professionals that spend a large part of their day in the car or simulator in 21 different track layouts, the others by people that mostly take the car to work or journalists that can be persuaded by the $$$$.
rogazilla
rogazilla
My example on production vehicle is simply trying to explain a simple EGR valve changed the engine character enough to change the torque curve. When they do the mapping on these engine, I assume the more anticipated part change or incremental update is easier to anticipate the characteristic of the engine and map it to fit a driver's feedback and also make the car drive-able.
When we saw Merc lapping none stop during testing the last few year, part is testing the reliability but the engineers are testing different settings and probably coming up with many map settings. How much time you are spending to understand a component versus how much time you can spend to test engine settings probably does compromise things. When you start putting old parts, new parts and things together on a PU, it probably makes little differences in the map and as sensitive as the drivers are to this car, it could be noticeable.
Sparky
Am i looking at the honda/renault PU thread or renault f1 team thread?
Wanted to know if there was any more info on the retirements last race but looking here ended me up in a honda nsx drivability discussion...
PowerandtheGlory
PowerandtheGlory
Let's get it back on track - Renault are due to bring ".......new bodywork, braking and suspension updates to China...." any body have any news on these parts on the cars yet?
“I don't believe in luck, luck is preparation and taking your opportunity” Ross Brawn
Capharol
Capharol
21
https://www.motorsport.com/f1/news/ricc ... ontent=www
Daniel Ricciardo reckons he and Renault have been trying to be "too clever" on Formula 1 weekends chasing the perfect set-up.
As part of a deep analysis done by the team after the Bahrain Grand Prix
Ricciardo not yet in tune with "different beast" Renault, Ricciardo says the outfit came to the conclusion that it has lost out by constantly seeking out improvements with its car rather than settling on a solid baseline.
and from what i have read they bring a new MGU-K (but that is more relevant in the other Renault-Topic)
PowerandtheGlory
PowerandtheGlory
Capharol wrote:
11 Apr 2019, 12:47
Do you know where it was reported that they have a new MGU-K?
Capharol
Capharol
21
PowerandtheGlory wrote:
11 Apr 2019, 13:02
Capharol wrote:
11 Apr 2019, 12:47
not 100% sure, but i believe it was motorsport.com aswell but i can't find it anymore :evil:
Edit: found it on Racefans
https://www.racefans.net/2019/04/11/ren ... -problems/
All four Renault-powered drivers will use a new specification of MGU-K this weekend as the manufacturer works to solve the problems it has suffered since the beginning of the season.......
Nico Hulkenberg confirmed he will take a new power unit this weekend following his retirement from sixth place in Bahrain.
“We worked on reliability to get on top of the situation,” he said. “It’s a pity we lost a great result there but that’s gone.”
“For me it was a failure on the PU side,” Hulkenberg explained. “We had a problem there, that’s why I’m onto my second engine now.
PowerandtheGlory
PowerandtheGlory
Capharol wrote:
11 Apr 2019, 13:30
11 Apr 2019, 13:02
Capharol wrote:
11 Apr 2019, 12:47
Brilliant - thanks! i always forget to check Racefans!! :D
PowerandtheGlory
PowerandtheGlory
Fingers crossed on the reliability again this weekend, Hulk looks on-it again
Jambier
It's a shame not to have be able to fix this before season.
So all car already reach their MGU K allocation for the year
HUL already on second engine.
If reliability is now here, it is not a big deal, but that will cost some points ultimately.
I've also read that if proven reliable they will unleash more power.
For now, the team seems to have a good pace in FP. But still a huge work to do on chassis to catch the top teams
Ground Effect
Ground Effect
Jambier wrote:
12 Apr 2019, 14:03
It seems reliability is a bit of an issue for all, except Mercedes. Ferrari has shown a bit of a soft underbelly. They've changed CE for the works team and Haas, Honda have had to change Kvyat's unit today, though there's is a precaution and could still be used. If there's more power to unleash with these changes, then it may be worth it, depending on how much of course.
Jambier
Good qualy knowing that it is their weak point
I hope to see them clear 4 force in race and really begin the season
