McLaren MCL38
FittingMechanics
FittingMechanics
16
Re: McLaren MCL38
genarro wrote:
26 Feb 2024, 11:41
FittingMechanics wrote:
26 Feb 2024, 08:48
wiktor977 wrote:
25 Feb 2024, 20:14
I remember that he was driving very slow, which is not normal during flow-vis test.
It was definitely intentional. He did a whole lap on the pitspeed limiter (100kph). It makes sense to me, the flow of air changes as speed increases. If you want to verify what is happening at low speed, you do a low speed flow-viz run.
wasnt that clutch problems related, that he did the whole lap in 2nd gear?
I doubt it. It was pretty obvious he would speed up to 100kph and then continue.
billamend
billamend
Re: McLaren MCL38
_cerber1
275
Re: McLaren MCL38
De Wet
Re: McLaren MCL38
Some interesting shapes...
_cerber1
275
Re: McLaren MCL38
Zaamy
Zaamy
Re: McLaren MCL38
Macklaren
Macklaren
Re: McLaren MCL38
WHOA! what's that?!
mwillems
Re: McLaren MCL38
Are we certain that is new? it looks the same to me.
-Bandit
Zaamy
Zaamy
Re: McLaren MCL38
mwillems wrote:
27 Feb 2024, 22:54
Yes think you’re right actually, the lack of paint threw me off
LionsHeart
LionsHeart
Re: McLaren MCL38
It's kind of one specification. Oh, I was getting excited.
Edit: I looked for a long time and found only one difference. The upper fourth flap, which is attached to the nose cone. One has the Guerney flap, the other does not, no other differences.
Mansell89
Mansell89
Re: McLaren MCL38
ImageCourtesy of Albert Fabrega- the usual rear wing comparison shot :)
https://pbs.twimg.com/media/GHamEBRWYAA ... ame=medium
Mansell89
Mansell89
Re: McLaren MCL38
Mansell89 wrote:
28 Feb 2024, 12:57
https://pbs.twimg.com/media/GHamEBRWYA ... ame=medium Courtesy of Albert Fabrega- the usual rear wing comparison shot :)
Is it a trick of the camera or do our intakes/sidepod look narrower this week? Compare to Ferrari for example?
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL38
Mansell89 wrote:
28 Feb 2024, 12:58
Mansell89 wrote:
28 Feb 2024, 12:57
Intake is the same. It flares out further but that bit of the sidepod is obscured. I do think we will see development in that area on the MCL38 in the next upgrade package, coupled with front wing and maybe some more sculpted underpod work
Seerix
Seerix
Re: McLaren MCL38
101FlyingDutchman wrote:
28 Feb 2024, 12:59
Mansell89 wrote:
28 Feb 2024, 12:58
Mansell89 wrote:
28 Feb 2024, 12:57
Sidepod cover is off, so it seems it's smaller. It would stick out more if it was on the car.
101FlyingDutchman
101FlyingDutchman
Re: McLaren MCL38
Seerix wrote:
28 Feb 2024, 13:01
28 Feb 2024, 12:59
Mansell89 wrote:
28 Feb 2024, 12:58
Expressed myself badly. The sidepod cover when attached flares out. It doesn’t run straight back from the side of the inlet. outwash management presumably. Looks like there is definite room to tighten up the bodywork if they can manage the airflow
