Mercedes W17
michl420
michl420
Re: Mercedes W17
Question is, will this spokes cool the tire because of the air that goes besides the brake assembly, or heat the tire because of the brakes. What is desired this year? Normally cooling.
johnnycesup
johnnycesup
Re: Mercedes W17
venkyhere wrote:
07 Mar 2026, 14:14
I don't think there will be any damping effect, since pressure would equalize all over the tyre very quickly. The only advantage I can imagine is more heat capacity (due to more air mass) which can delay 'deg' of the core by a few laps.
The "extra" air mass in that little spoke pocket has got to be like 10-20g, completely irrelevant as far as heat capacity goes.
Re: Mercedes W17
The spokes could provide extra surface area for heat transfer.
Beware of T-Rex
venkyhere
43
Re: Mercedes W17
johnnycesup wrote:
08 Mar 2026, 15:56
venkyhere wrote:
07 Mar 2026, 14:14
what do you think is going to be the air mass enclosed between a 'regular' rim and tyre ?
Re: Mercedes W17
Beware of T-Rex
SiLo
144
Re: Mercedes W17
Has anyone figured out how the extra little winglets on the rear wing tips are legal yet?
Felipe Baby!
johnnycesup
johnnycesup
Re: Mercedes W17
venkyhere wrote:
08 Mar 2026, 20:30
johnnycesup wrote:
08 Mar 2026, 15:56
venkyhere wrote:
07 Mar 2026, 14:14
From a very quick calculation, around 240g?
The tyre itself and the rim weighs like 20kg, that's why I think the heat capacity of the air is not really meaningful.
Re: Mercedes W17
SiLo wrote:
08 Mar 2026, 22:09
FNTC wrote:
09 Mar 2026, 19:59
Lol... FIA says you can put the regulation box for the "rear wing brackets" where you want almost. So Mercedes puts it on top of the rear wing outside the rear wing regulation box. :lol:
Beware of T-Rex
PowerandtheGlory
PowerandtheGlory
Re: Mercedes W17
michl420 wrote:
06 Mar 2026, 12:20
Is that ballast on the under/rearside of the "gearbox"?
I think maybe jacking point.. but coukd easily be ballast too. :wink:
“I don't believe in luck, luck is preparation and taking your opportunity” Ross Brawn
venkyhere
43
Re: Mercedes W17
PowerandtheGlory wrote:
09 Mar 2026, 22:31
michl420 wrote:
06 Mar 2026, 12:20
I don't know how what a ballast looks like, but that definitely isn't a "jacking point" - that will be on the crash structure, even if present (which it isn't). In this pic we can see that the floor itself isn't attached (=> that 'brick' will be the place where a part of the diffuser (that is an extension of the floor) will come).
So, it's either ballast or 'I don't know'.
Lasssept
118
Re: Mercedes W17
nicolas carpentiers
Farnborough
Farnborough
152
Re: Mercedes W17
09 Mar 2026, 22:31
michl420 wrote:
06 Mar 2026, 12:20
Looks like ballast, as jacking point needn't be anything like that cross section to effect a facilty like that.
Conventionally its tungsten used for ballast, but that would be a big chunk if made in that material.
Probably to stop the harmonic effects they're experiencing over at AMR :lol:
SiLo
144
Re: Mercedes W17
09 Mar 2026, 22:09
SiLo wrote:
08 Mar 2026, 22:09
FNTC wrote:
09 Mar 2026, 19:59
Thanks! This is pretty funny really. I assume other teams will do the same.
Felipe Baby!
Stu
Re: Mercedes W17
07 Mar 2026, 13:01
Hollow wheel spokes
https://images.ps-aws.com/c?url=https%3 ... 20x742.jpg
As mentioned by me previously here, it increases the volume of air that the tyre ‘sees’, reducing the pressure change during compression of the tyre and provides a cooling/temperature control element for the tyre. These are big spokes!!
Re: Mercedes W17
Beware of T-Rex
