I suppose it wouldn't be too hard to have a fixed ratio to step 64k rpm down to roughly 18k but as you say you have the opposing destinations of the two parts of the powertrain.
For some reason I thought the KERS would be applied at a steady RPM (i.e. flat out in top) but given the way they gear the engines to max out for optimum time per lap I can't imagine that happening, unless some changes go on with that strategy.
And obviously there was the talk earlier on this thread about whether the boost would push the engine over the rev limit.
At the mention of strategy, does anyone think the teams might abandon the push to pass system and use this technology for fuel saving with the incoming re-fueling ban? Less fuel weight means a faster car at all points on the curcuit, plus reduced tyre wear, plus a host of other gains I haven't forseen I'm sure.
Anyway, somewhat more on point...
So they will apply KERS as they shift through the gears which isn't too bad as that would be, what a 4,000rpm gap? The flywheel will taper off from distributing useful amounts of power at what, the 20-40,000rpm range? (I would imagine Batteries have the same problem as they approach a potentially damaging state of charge, like too low) so the gearing difference is slightly less horrendous than it could have been... Still plentty enough to put a team off I should imagine.
The more I think about it, for KERS to realise it's full potential, you really need to disconnect the engine from wheels, in the traditional sense. It will require some sort of mechanical coupling, but one shared with the KER's rather than used by it (especially as the Power storage of KERS increases). This would be different to the current approach of simply adding power at the crank, or gearbox.
The best way I can think to describe it would be:
KERS and the engine adding power to seperate sides of A limited slip differential. the output of the diff would then be passed to the existing diff system where it is split between left and right wheel.
Each side could be sepearatly geared to suit it's own 'power-band'.
This would raise the possibility that engine speed would not be directly related to wheel speed (and really push the case for the use of C.V.T.s...) I think.
