Unknown control lever, heated seat maybe?
670
Re: Unknown control lever, heated seat maybe?
Wing warping is a very good way of controlling roll
The downside is that you don't get a very good wing
hardingfv32
hardingfv32
Radio communications posted by Scarbs would seem to confirm that the brake systems have two types of bias adjustment used concurrently. The normal bias bar at the pedals and the hydraulic proportioning valve, "quick shift" unit.
[00:37:32 Heikki told to go minus 1% brake balance which equals 1 “full turn” on his adjuster. Reminded to only use the “quick shift” balance adjuster for T10. As he examines driver data in the car, told to focus improvement on exit of “last three corners”]
Brian
speedsense
speedsense
hardingfv32 wrote:Radio communications posted by Scarbs would seem to confirm that the brake systems have two types of bias adjustment used concurrently. The normal bias bar at the pedals and the hydraulic proportioning valve, "quick shift" unit.
Brian
The "quick shift" was designed by Ferrari in 2006, and allowed a three way adjustment of brake bias according to corner entry speed that can be set according to the track.
"Driving a car as fast as possible (in a race) is all about maintaining the highest possible acceleration level in the appropriate direction." Peter Wright,Techical Director, Team Lotus
