2014 season - Ugliest noses ever?
ecapox
Re: 2014 season - Ugliest noses ever?
Is there a nose minimum length?
FrukostScones
ecapox wrote:Is there a nose minimum length?
I think 700mm or 750mm?
"I ain't with the FIFA, I'm in Tokyo." LH
f1316
88
For those who haven't seen it, here's one visualisation:
Doesn't look too bad to me
FrukostScones
this visualization is obsolete and inaccurate
Yeah the wings are too wide.
TEHNOS
Jonnycraig
Jonnycraig
Martin Brundle said a few races ago that he was led to believe the noses will look like the 09 Brawn.
So some cars could look like the Fw-26 for the side view in 2014 but with a drooping surviving cell and a thinner nose cone
FrukostScones wrote:
WilliamsF1 wrote:
FrukostScones wrote:yeah krisfx, the Williams looke fine. But I think 2014 will look more like the Honda 2008 testing hybride!
http://www.motorsport-magazin.com/image ... 171967.jpg
http://www.motorsport-magazin.com/image ... 171972.jpg
It is to be noted that the front wing is 75 mm above the reference, the honda nose looks a over 185 mm
Yeah, it will be more inclined over its length :mrgreen: the Honda nose mixed with this thing is 100% 2014
medically inaccurate
http://www.motorsport-magazin.com/image ... 171917.jpg
http://www.tierportraet.ch/bilder/ameisenbaer.jpg
Honda tested another nose that year. a nosecone which is lower and closer to the 'anteater' :wink:
Jonnycraig wrote:Martin Brundle said a few races ago that he was led to believe the noses will look like the 09 Brawn.
That's not ugly at all.
And while i'm at it those anteater Mclarens weren't ugly either, much prettier than current high nosed cars actually.
A bunch of doom mongers if you ask me...
My only problem with F1 2014 is lack of power.
Hail22
144
Like this?
Gilles Villeneuve
FrukostScones
well this is the 2009 Brawn. But the 2014 noses won't look anything like it.
krisfx
krisfx
It is to be noted that the front wing is 75 mm above the reference, the honda nose looks a over 185 mm (nose tip almost in line with the front axle which would make the nose tip at around 240 mm above reference)
It also has to be noted that they are both testing hybrids from 2008 cars so of course they aren't to the 2014 regulations, but it gives an idea of what it could vaguely look like... #-o
henra
henra
Blackout wrote: Honda tested another nose that year. a nosecone which is lower and closer to the 'anteater' :wink:
http://www.servimg.com/image_preview.ph ... u=14795526
The upper one minus the "angels-wings" might be not too far from what one would expect with the 2014 regulations.
I haven't seen any regulation for the thickness of the nose behind the minimum area defnition 50mm from the forward end of the crash structure.
As the main task for 2014 will be getting as much air flow to the diffuser I expect to see noses that allow as much airflow to the sides and under the nose as possible.
Back in 2009 they had DDD + Beam Wing thereby not so much trouble getting DF at the rear. Thus they could use wide noses which create DF at the front yet don't feed too much air into the tray/underbody area, thereby hampering somewhat the whole underbody aerodynamics including the diffuser.
With next year's regs this doesn't look like an attractive option.
So, my bet is on smallish noses somewhat similar to that Honda or the McLaren Mp4/22 possibly even steeper at the front to get more free space underneath the chassis.
shelly
shelly
136
I think that some teams will try the "walrus" option, as it is the one that makes for easier reproduction of the flow conditions of the current generation of cars. So a high but very short nose with pillars protruding forward, cut-out to comply with the regs A drooping nose gives a completely different flow to the underside of the nose, tea-tray and suspension: in the ned it could e also optimised, but it is a bigger leap from the current standard.
Given enough development, I think that a low nose - high chassis, maybe with pullrod front suspension, will be the most interesting configuration. Hope that some team will pull a mix between 1993 footwork and 1995 minardi
twitter: @armchair_aero
