And the old layout has the following disadvantages compared to a Mercedes layout IMO:
1-The compressor is too close to the turbine (some engineers do not hink this is a disadvantage, but others, Illien for ex, do)
2-Compressor/intercooler pipes are too close to the exhaust pipes
3-Compressor and turbo are respectively too far from the intake and exhaust, partly because of the disk shaped compressor airbox
4-Gearbox needs to be larger/longer to accomodate the T, the C, the C air box etc.
5-Gearbox/'clutchbell' housing needs bigger holes to let the C and T pipes pass.
So:
-Because of (1) and (2):
the car needs larger intercoolers ---> drag/aero penalty, weight penalty
or
car needs more heat shielding ---> that costs wieght, space and time
or
engine is less efficient...
-Because of (3):
tubo lag is bigger ---> MGUH spend more time and energy reducing lag ---> MGUK and engine become less electric power
-Because of 4: Gbox CoG is swept backward ---> less flexiblity regarding wight distibution. Gbox foot print on the floor is bigger, sidepods/wasp waist/coke bottle shape are larger --> aero penalty
Because of (5):
Gbox stiffness is reduced and/or its weight is increased
And I'm sure I forgot some other points : P
But as I said in the first page, there is still a big improvement margin especially regarding point (3) and (4).
RBR did well with the RB10 concerning point (2). But there is still a lot to do.
Why not completely wrap the compressor (and the intercooler?), like this Honda mocke up did, in order to isolate it from the turbine's heat, in order to minimise point (1) problems?
