Toro Rosso STR11 Ferrari
aral
aral
26
Re: Toro Rosso STR11 Ferrari
WaikeCU wrote:Wonder if the '16 Ferrari PU is larger than its predecessor? And if so, if TR would had the '16 PU, would this tight packaging be even possible?
all reports are that the 2016 unit is smaller, with a shorter block and repackaged ancilliaries
Peter1919
Peter1919
Sevach wrote:I expected this car to look "big" after the things we heard about the 2015 Ferrari engine...
Yes but wasn't the Renault engine last year the largest on the grid? So to go from last year's Renault engine to last years Ferrari engine actually probably gave them some room to slim the car down a bit
Could be...
seezung
seezung
56
Wow...
I did not expect that one either. Surely that back will have to open up when go out of winter testing and onto the warmer race weekends. Still, that even rivals the pre-2014 cars which had extremely lean rears.
timbo
timbo
113
Mighty impressive, hats off for STR engineering team!
oetger
They do not have as mutch "rake" as their sister team..
I expected that. 8) I said las year that thanks to the Ferrari V-integrated intercooler (and its small and flexible water rad) and the boomerang shaped engine oil rad placed outside the sidepods, the STR should have tiny sidepods.
If they had a decent amount of time to adpat to the new engine, they could produce even thinner sidepods.
And they are still innovative.
Crazy...
240
beautiful car from Torro Rosso as usual.
The gearbox is floating very high above the floor, reminds me of one of the mclaren cars a few years ago.
Well, i hope we see this car at the front, it doesn't see to have any draw backs in the design, as last year's car was very good. Now they should have more engine power as well.
BlackSwan wrote:
They are running without sidewall on the rear wing squirt slots. (upper right corner on the image)
Good spot. Never seen that done before!
You have to hand it to the Torro Rosso engineering team, they're delivering beautifully packaged cars year after year, they're a piece of art.
SectorOne
In 5 years time you´ll need a damn microscope to see the sidepods on the STR.
I keep looking at the images and it doesn´t even look real. :)
RicME85
52
that naca duct =D>
