If you were Mosley?
NickT
- Any engine configuration desired, but all limited to 1000hp
- In flight refuling and tyre changes
- Slicks
- Absolutely no driver aids
- Additional points for the most lurid tail slide and recovery
- Manual 4 speed gearbox in classic "H" patern
- Low downforce aero to include air brake to limit top speed
- FIA remote controlled air brake to replace flag system
- Drift club style qualifying, the most sideway lap on pole
NickT
Sawtooth-spike
shall we go for classic arcade gear box with just Hi-Low on it?
I would just want a formula where the cars look slick (with out all the chimneys and stuff)
No drivers aids, just Semi gearbox
Bigger deffuser, and less wing
big slick sticky tires
1 engine per weekend
Engine size 3L, Any Way you want to do it, Or a 1.5L Turbo
I would also like there to be some kinda of thing to promote saving fuel, like a weight advantage for running a engine which burns less fuel, becasue this technoligy could be moved over to road cars.
I believe in the chain of command, Its the chain I use to beat you till you do what i want!!!
Jason
NickT wrote:- Manual 4 speed gearbox in classic "H" patern
I use that on my car, I hate full AUTOS.
Never regret what you do, but only regret what you don't do. - Jenson Button
http://batracer.com/-1FrontPage.htm?LW
johny
the rule i most like for 2008 is the 5% organic in fuel, that's the way f1 should go, i don't mind new winglets or using a wind tunnel 24/7
Jason
johny wrote:i don't mind new winglets
X-wing :twisted:
wrk
moveable wing tips like on a plane. adjustable by the driver from in the cockpit......
now theres a thought!!!!
gentlemen start your engines......
johny
and why not a auto-pilot with the optimun race line? forget about drivers, engeneers will control the car from the pit wall
Tom
How about ailerons to promote ovetaking. Just fly over your opponent :D
Of course MS would just attemp to land on top of the others.
Murphy's 9th Law of Technology:
Tell a man there are 300 million stars in the universe and he'll believe you. Tell him a bench has wet paint on it and he'll have to touch to be sure.
Ciro Pabón
106
FIA released 3-D detailed renditions of a summary of proposals presented by different groups, in search of F1 ideal vehicle for 2009 season:
- Fans e-mail and forums
- Pilots Association
- Bernie and Max
Ciro
furnik28
furnik28
go and get a real job he should get the head job at the CIA he would be good at that look what he did with f1.
rok
Jason
-yes for refueling
-Slicks
-Traction control
-Launch control
-NO team orders
-AUTO Gearboxes
-Limited budget at 400m GBP
-V12
-revving at 23,000rpm
-around 950bhp
-must weight at least 95kg
How's now manchild?
manchild
manchild
Jason, old turbos that reached 1500 hp at qualifying never revved even 13.000 rpm. So why would they rev at 23.000 with modern technology and still make "only" 1500 hp? :?
jaslfc
jaslfc
i think we are forgetting the main point.. if i was mosley.. having engine that produces around 900 bhp should be sufficient.. but they gotta find a way to up the mechanical grip compared to aero so there wil be more overtaking
RH1300S
RH1300S
No refuelling
Fuel restricted races and testing (they won't run out of fuel these days, too much data coming out of the cars). Here's the rub.........you can use as much fuel as you want in the race just as long as your tank is big enough, but you trade with testing miles. The FIA will reserve a minimum fuel allocation for each race weekend to ensure that teams don't get to a point where they have used their entire allocation and are unable to compete. The amount is chosen by the team.
Energy recovery systems allowed, but forced induction is not allowed
Tyre changes permitted (any number) - but not compulsory. Although there will be a tyre allocation per car per weekend.
Revert to slick tyres, with open competition from manufacturers (no control tyre)
4 stroke N/A engines - any capacity & number of cylinders
Manual gearboxes with one reverse gear and maximum 7 forward gears with a mechanical link between the lever and gearbox (sequential or H pattern shifts allowed). An electronic disconnection between the engine/gearbox is allowed (think motorcycle quick-shifters), but no other control of the throttle (i.e. kickers between gears).
No traction control or other driver aids (perhaps a control ecu is the only way)
Homologate bodywork with a limited number of changes allowed in a year (and that includes changing wings for different circuits :wink: ) - Homologations must include different cooling solutions to cope with whatever the weather throws at it.
Unless every other form of motorsport on the planet changes, wings must stay as F1 must be the fastest around a closed circuit.
Open the pitlane for walkabouts over the race weekend (the teams will just have to plan around it and not get precious about their cars), cars must be on display, drivers must be available for autographs.
Jason
RH1300S wrote:4 stroke N/A engines - any capacity & number of cylinders
You have to control the amount of cylinders so no team getting the advantage of extra HP's(or whatever). Capacity is not imortant but the amount of cylinders must be controled to ensure fair racing.
