Inboard brakes- worth it?
Yes
No votes
No
48%
Dependent upon context
52%
Total votes: 21
Re: Inboard brakes- worth it?
roon wrote: ↑
14 Aug 2018, 01:07
The far end of a driveshaft could be made lighter than a rotor, caliper, and upright flanges/bosses. But the driveshaft will absorb energy under braking. Would this make the brakes feel less responsive? The immediacy of a directly connected rotor is lost.
Would lock-up be reduced or exaggerated? The driveshaft would reduce the initial bite/torque from the brake. But the shock absorbing effect may create a confusing feedback as the driveshaft builds and releases energy.
Two words.. CV joints.
Four of them! That's a lotta weight.
roon
roon
412
PlatinumZealot wrote: ↑
26 Aug 2018, 22:01
roon wrote: ↑
14 Aug 2018, 01:07
Indeed, but you also get to deduct:
-brake rotor and carrier
-caliper and pads
-hydraulic lines and fluid
-mounting bolts
-upright flanges
-ducting
Plus wheel structure might be further optimized without concessions to brake rotor accommodations.
Those might still be lighter becuse the CV joints have to be steel/titanium. The brake stuff are carbon and aluminum.
