I think that is the key, the acceleration torque. From the little i have read about TC/ESP in electric motors, is that they generate a reference torque for the controller, and that reference torque is generated via a tyre model or something like that.WhiteBlue wrote:The way I see this working is a KERS acceleration profile that works proportional to the throttle position potentially with a bit of a ramp up. It will be launched by the driver button but will modulate the acceleration torque in a pre programmed way.
This is sad, because i think we never will see how this really worksWhiteBlue wrote: Quite a bit of programming involved in that KERS controller. Drivers must be prepared to feel different corner exit response depending whether they use KERS or not. They will probably have even more of an adjustment to make to braking. I doubt that braking with KERS and without will feel the same.
One can only speculate which parts of the KERS control will be in the KERS subsystem and which part will be executed by the SECU.
i hope that i'm wrong...
